Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to cover these door pods?
Old 02-28-2009, 03:40 PM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
Pull the fabric as hard as you can side to side in both directions and staple it or glue it on the back of the pod. Then you can pull the fabric top to bottom. You need to pull it as tight as you can get it, and you should be able to pull out all the wrinkles.
