How to cover these door pods? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2009, 01:49 PM
Ok, I tried to cover this, first time doing something like this.
It looks ok, but if you look underneath I had to cut out the ripples and patch together. How do I cover this so as to not get an ripples, folds, creases or anything? I get so frustrated.
I have another one to do and also would like to redo this one.
Thanks,
Derek
Old 02-27-2009, 03:26 PM
DanTwoLakes's Avatar
Wiki Edits: 22
What did you use to glue the fabric down with? You need to do this in stages, not all at once. Basically, you need to start at the large and small speaker openings. Attach the fabric to the pod 1" completely around the perimeter of the large opening and up to the small speaker opening with High Heat Resistant contact adhesive. Don't cut out the openings until you are done. Once that is solid and the glue is dry, you can pull the rest of the fabric out and away from that point. The low spots you will have to glue to hold the fabric in place, but the rest doesn't have to be glued on the front, just on the back. If you can staple into the back side, that would be easier than gluing.
Old 02-27-2009, 03:57 PM
I used 3M 77 or 90, can't recall right now.
So when I get down to the bottom where it is curved, i shouldn't have any creases if I do it the way you suggest?
Thanks,
Derek
Old 02-27-2009, 07:01 PM
Wiki Edits: 22
3-M 90 (super trim adhesive) is fine, but don't use 77 or 74, they will not work, cuz they're not high temp adhesives.
Yes, if you do it like I said, you should be able to get it smooth. It looks like the fabric is some kind of imitation suede. Does it stretch? If not, it will not be as easy to get the wrinkles out, but it still can be done.
Old 02-27-2009, 08:20 PM
it is a faux suede and it doesn't stretch,but I got some tweed and will be replacing it with that. Also got some better high temp glue. http://www.yourautotrim.com/perhittrimad.html
thanks for the help. gonna try this wknd.
Derek
Old 02-28-2009, 08:04 AM
Wiki Edits: 22
Be careful with the tweed that you don't spray too much glue on it, or it can soak through. Stay back 12" when you're spraying.
Performance spray glue has 3 different spray patterns. Use no more than the medium pattern. Good luck.
Old 02-28-2009, 03:12 PM
ok, I am getting frustrated again. I started with the speaker holes and let it dry, when I try to wrap it around, I still get that big overlap.
Name:	DSC02178 [800x600].JPG
ID:	36613   Click image for larger version
Name:	DSC02182 [800x600].JPG
ID:	36614   Click image for larger version
Name:	DSC02183 [800x600].JPG
Old 02-28-2009, 03:40 PM
Wiki Edits: 22
Pull the fabric as hard as you can side to side in both directions and staple it or glue it on the back of the pod. Then you can pull the fabric top to bottom. You need to pull it as tight as you can get it, and you should be able to pull out all the wrinkles.
Old 03-01-2009, 12:29 PM
well, finally got'er done. The part below the big speaker hole was the worst. I pulled and pulled and just when I thought I couldn't pull anymore, I pulled some more. My thumbs were sore. It didn't come out 100% but maybe 99%. I even got brave and used some volara for the GM symbol.
Dan, I can't thank you enough. There is just no decent info on the web for auto upholstery like there is for everything else. I read a post that said you were leaving, sure glad u didn't.
Name:	DSC02189 [800x600].JPG
ID:	36623   Click image for larger version
Name:	DSC02186 [800x600].JPG
ID:	36624   Click image for larger version
Name:	DSC02188 [800x600].JPG
Old 03-01-2009, 12:37 PM
one more question. On my existing covered one, can I cover over it or should I remove the old fabric first?
Old 03-01-2009, 01:56 PM
That looks really good. Nice job. The bowtie came out really nice!!
Old 03-01-2009, 03:15 PM
Great work and glade to see you stayed with it. Some times you just need to walk away and come back. Has worked for me before, many times. Looks awesome.....
Old 03-01-2009, 03:35 PM
Wiki Edits: 22
Congratulations! You could go over it if the fabric is thin enough, but you take the risk of it looking different than the other one. I would remove the old fabric first.
Old 03-13-2009, 05:50 PM
dbinnc
I seen the photos of the door panel that you finished. I thought you did a great job.
Kirk
Old 03-13-2009, 11:17 PM
Thanks!
What the ***** is wrong with my timing cover/ harmonic balancer!!! sexypizzaman Engine 56 10-28-2008 04:49 AM
Gear Drive to Timing Cover Clearance Double_v23 Engine 5 01-11-2008 12:08 PM
Gear Drive to Timing Cover Clearance Double_v23 Engine 7 01-10-2008 08:12 AM
Valce cover Oil leak problem / PCV system question hotrodf1 Engine 7 05-01-2007 03:44 PM
Timing Chain cover '67Pony Engine 2 09-08-2003 12:39 PM
