How crappy would a motor run if....... - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2002, 11:02 AM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Question How crappy would a motor run if.......
I was wondering how a motor would run if it was built for a supercharger(8.5-1 comp, cam with 112-115 lobe seperation), but was ran with a 4 barrell intake N carb untill I could afford the blower? Id like to go this route, but will it run like doo doo? HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 10-17-2002, 11:04 AM
drgnwgn289's Avatar
Post
I have heard of a lot of people doing that...*****, I even did it for a while, it won't run bad, just won't be runnig to its full potential.
Old 10-17-2002, 01:01 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
Talking
i wouldn't be too worried. if i've been paying attention to your posts, sounds like you've got many, many parts kicking around. maybe you could get some smaller cc heads to run on there until you get the s/c and then switch'em back.
JB
"Well done is better than well said." - Benjamin Franklin (1706-1790)
Old 10-17-2002, 02:30 PM
1meancuda's Avatar
At a loss for words
Post
I think you should seriously check out the latest issue in Car Craft. They dyno'd a Vortec headed 350 with a 4 barrel with 3 different cams of the same duration except different LSA (108, 110, 114 I believe). There was not a tremendious power lose between the lowest and highest and they picked up better vacuum with the bigger seperations. I think it would probably run pretty well, but like drgnwgn289 said, probably not at its full potential.
