how to cut braided fuel line? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2007, 02:51 PM
Longboard's Avatar
Last journal entry: Well she is finally done!!!
What's the best tool & technique to cut braided fuel line?
Old 03-31-2007, 03:07 PM
powerrodsmike's Avatar
Wiki Edits: 161
Tape it up and use an abrasive cutoff wheel. Blow the junk out of the hose afterwards and remove the tape.
That's how I've always done it.
Mikey
BE different....ACT normal.
Old 03-31-2007, 03:22 PM
41willys's Avatar
Blowin' it
Last journal entry: Running again...
Wiki Edits: 11
I have always taped it, and cut in the middle of the tape with serrated metal snips. It has always made the least amount of mess and works quickly.
Jason
Old 03-31-2007, 03:59 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
I wrap a length of electrical tape around it then attach a hose clamp around the tape. Then I take a hack saw and cut it along the hose clamp.
Never tried using a cut off wheel, I'll have to check that out.
Old 03-31-2007, 11:19 PM
STRKD89FB's Avatar
408 Stroker
I wrap the area I am going to cut with black electrical tape and I have used a set of tin snips to cut mine. Makes a nice clean cut and no mess.
Old 04-01-2007, 08:46 AM
Frisco's Avatar
Glad To Be Here
See this thread for more info and pictures.
Cutting braided hose
Old 04-01-2007, 12:43 PM
Longboard's Avatar
Excellent, outstanding, and many thanks! One more question if I may. Must you crimp(?) each fitting?
Old 04-01-2007, 01:38 PM
A SHARP chisel and a hammer!!!!
Old 04-02-2007, 08:03 AM
Frisco's Avatar
Glad To Be Here
The AN style fittings that are used with braided lines are not crimped.
The inner portion of the braided line is pushed onto a tapered section of the AN fitting and the outer nut of the AN fitting creates the seal against the OD of the braided line as it is tightened.
Old 04-02-2007, 08:04 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
On the Fittings and Steel Braid low pressure (under 350#) that I have used, you push the Ferrule on the Hose (which is the hardest part), then screw the Fitting into the Hose (the Ferrule has Threads).
On real High Pressure Hose (over 2000# p.s.i.) 95%+ of those ARE crimped (much better clamping method)-
Old 04-02-2007, 06:20 PM
Jeg's sells a tool for cutting it...best investment yet...woo hoo
Old 05-21-2014, 12:55 AM
cutting braided fuel line
I just wrap tape around where I want to cut it, & used a small cut off wheel...worked fine!!
Old 05-21-2014, 02:41 AM
malc's Avatar
Living At The Speed Of Life
Hey Marty, you must hold the record for your first post after your join date....
To a seven year old thread.
Old 05-21-2014, 05:05 AM
Last journal entry: 50 Ply wagon
When you get ready to put on the AN fittings....remember to remove tape from end of hose.
Most people try to just shove the first part of the AN fitting onto the hose. The part actually has left handed threads in it. Put the hose in some soft V-clamps in a vise and turn that AN part onto the hose so it seats all the way in. I also use alittle oil on the inside of the hose and threads as I put the threaded part into the hose.
Old 05-21-2014, 06:22 AM
Masking tape and cut it with a larger pair of SHARP tin snips or a VERY fine blade in the band saw.
Revamping Fuel System topdogger Engine 6 12-29-2006 01:13 AM
sbc fuel line problem jw4413nv General Rodding Tech 8 12-22-2006 04:11 PM
FUEL LINE & TRANS LINE SIZE/TYPE leejoy Hotrodding Basics 7 11-29-2005 11:59 PM
Fuel Line Vent jcdaly Engine 1 02-19-2005 10:07 PM
Chevelle Fuel line question heavychevy Engine 1 04-01-2003 11:39 PM
