How is this dash made? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2004, 04:16 AM
This is from rad rides site - I understand that he starts with foam to get the shape , but I dont understand if it is body fill or fiberglass with body fill after that - looks like to would weigh a ton . do you think this is a template for fiberglass later? any thoughts on the process.
http://www.radrides.com/projects.php?cursec=9&timg=8
Old 12-30-2004, 06:54 AM
This seems to be foam out of the can. This gets pretty stiff and doesn't weigh much. But I don't think it's hard enough without further coating. You can knock a dent in this material with your fist without hurting yourself...
Regards
Martin
Old 12-30-2004, 07:21 AM
Thanks - I am sorry if you look at the addtional photos - it is a series - and looks like they move to fiberglass next- but if look at the last photo I cant tell if this would be the end product or what they use to make a mould from.
Old 12-30-2004, 08:18 AM
kristkustoms's Avatar
First name...............Shawn
The foam is just a mold. It the foam was in place in the final product, you couldnt insert the gauges into the dash.
Old 12-30-2004, 08:29 AM
one layer of glass, then a glass gel coat layer, then sand and use filler to finish
to much curve for the glass cloth to lay down, use chopped glass.
strong enough for a dash face.
on the back side, cut the foam and glass in (wood) bracing so it can't twist and crack the face
