How To Decipher 95-97 Ford Powerstroke 7.3 Heads? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2008, 01:02 AM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Question How To Decipher 95-97 Ford Powerstroke 7.3 Heads?
Hey Y'all!
I was Wondering if anyone knew how to read the Casting Numbers on these 95-97 powerstroke heads?
A buddy if mine is having a hard time finding the right heads & a good set.
As always thanks for your replies & any & all information is greatly appreciated..
Rob
"SlowRide66"
"Illegitimis non carborundum"
Old 01-30-2008, 06:22 AM
bondo's Avatar
Ayuh,.....
These guys will have your answer,...
Either in the knowledge base, or the forums proper.....
Old 01-30-2008, 09:43 AM
Irelands child's Avatar
Or here......http://www.ford-trucks.com/forums/index.php
Irelands child
Old 01-30-2008, 06:17 PM
Rob Keller's Avatar
Wiki Edits: 38
Thanks!
Rob
"SlowRide66"
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 03:50 PM
Small Block Ford Heads The Vandal Engine 2 03-30-2003 03:04 PM
heads for ford sheppard00 Engine 2 03-02-2003 11:55 AM
How do I install dual side pipes on on 97' Ford Ranger? John Rose Engine 2 01-15-2003 05:38 AM
460 FORD HEADS Smokeytires Engine 1 09-10-2002 08:46 PM
