how to degree a cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2010, 12:59 PM
how to degree a cam
I have always time my sbc dot to dot, but i really want to start getting into my engine builds a little deeper. If you run your timing and degree it 7 degrees advance what are the advantages? I don't understand the actual process of advance to 7 degrees or how ever you need to go. The reason i asked and some people already know there is an engine builder who ran a big mutha thumpr cam and he ran his timing 6 to 7 degrees advanced,and made big numbers. I want to degree my cam how ever you guys would recommend. Maybe i will understand the process. If anyone has any advice dos and don ts i would really appreciate it. Would i make more power degree the cam with no advancement? Im building a 350 with a 3.750 stroke bored 40. Alot of questions thanks for reading
Old 06-02-2010, 02:07 PM
The Flyin Wop's Avatar
Paisano
Last wiki edit: How to remove an ignition key lock
Wiki Edits: 4
Comp cams has a great degree wheel kit with all the goodies in it.I trhink youll have to get a cylinder stop for it.It even comes with a real informative dvd and instructions on how to do it and has some good tips in it.
I used to do it the old way with just a pointer and degree wheel,but this has soft springs you can put on your valves to check lift,etc. sells for about 100.00 bucks,unless you can borrow one.
Paisano
Old 06-03-2010, 01:54 PM
Ive done some researching,and found some get sites with detailed instructions. The only thing im not sure is finding your intake center line, it didn't really explain that very well. i know you have to divide 2 measurments together it get your intake centerline. You have to rotate from tdc counterclockwise and back to tdc i think and find the center measurement,but when i get the kit,and video to degree it im sure it will explain it a little better
Wich cam would you choose between these two? sbc 350 eric32 Engine 11 06-22-2009 05:57 PM
Would this Isky Hydraullic roller cam work good for my combo eric32 Engine 9 06-18-2009 04:36 PM
How To Degree A Cam Shaft ? ? ? SCHOONER Engine 1 11-27-2006 06:37 PM
Cam Degree Question rcm800 Engine 2 07-30-2006 06:55 PM
Degree that cam kseay Engine 10 05-02-2005 06:26 PM
