Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to determine gear ratio in Ford 9"
Old 10-21-2003, 05:12 PM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
Re: traction issue
Originally posted by tm454
First CK out your gear ratio and then get back to us. I tried to explain to the Troll with the imaginary Boss Stang he needed to CK his gear ratio and post back but I don't expect to hear from him. YOU WERE RIGHT ON GIRL, called it in the first post didn't you? Boss Troll is pissing around with the crew and cussing his little head off. Some people don't understand its not good to be caught in a LIE?? He's probably running bald tires, or did he say slicks???
Todd
Rat Rods Rule!
Todd, what are you talking about?
Kaylah; Yes jack up the rear end so both wheels are off the ground. You wan to turn the passenger side wheel because it is attached to the ring gear. The driver's side wheel goes thru the differential and, unless both wheels turn (the passenger side may stay still or even go backward), you will get bogus results.
