How Determine Ride Height - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2005, 01:16 PM
Hi all,
I have assembled most of the items to install air bags on a 77 c10 still looking for a few items before I begin. My question is after I have installed everything what should I do to determine acceptable ride height for the front end to prevent uneven wear of the tires. Are there any recommended senors or anything that would indicate a correct air pressure range when the truck is under a normal load compared to overloaded under rare occasions.
Thanks
Old 08-15-2005, 03:16 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Ride height is usually having the lower control arms level at stock ride height..this gives best alignment for tire wear and handling..So maintaining the factory geometry is important..If you are after a low rider then that may not be a consideration for you..
Air bags need 10-15 psi minimum..tho when using air bags as a suspension somewhere in the 40-50 lb range is about right...
Most of where I would concern myself is that the air bag supports the load and the air pressure does not exceed the manufacturers recommedations..
OMT
Ride height delimma wally8 Suspension - Brakes - Steering 8 01-03-2005 02:15 AM
Increasing Ride Height Slightly - what are my options? hduff Suspension - Brakes - Steering 8 10-19-2004 07:44 PM
Ride height 1937 ford pickup magnum2u Suspension - Brakes - Steering 0 08-21-2004 05:02 PM
problem with ride height!!! brian400ex Suspension - Brakes - Steering 3 04-17-2004 04:22 PM
raising rear ride height 67_Deuce Suspension - Brakes - Steering 5 01-18-2003 10:19 PM
