How to dial in a cam? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2013, 07:14 PM
Metal Twister's Avatar
Change is Opportunity!
Last journal entry: One More Seat
I was looking for good instruction on how to dial in a cam. I built an engine some 30 years ago and believe it or not I think its time to think about fireing it off! LOL I remember setting it up at 0 degrees but I got a bunch of plastic cam shaped plastic inserts for fine tuning it. Think I had better read up and find out what that is all about? Any good threads or reading material you can suggest that explains what I need to do here?
Old 04-25-2013, 08:33 PM
33Willys77's Avatar
If you dont have a degree wheel, get one and it should have all the info you need with it go complete it. Use the search engine with this site, you will find many threads on this topic.
Old 04-25-2013, 08:38 PM
I do have a degree wheel somewhere, hummm but where? I will do a search thanks,
Old 04-25-2013, 11:09 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
Here's a video on how to degree a cam.
Rich
Old 04-26-2013, 12:57 AM
Thanks that explained everything but what you do if it needs adjusting with the little inserts.
Dial Indicator alrobjr Hotrodding Basics 7 01-21-2010 07:19 PM
Dial indicator tommy evans General Rodding Tech 7 06-16-2009 04:56 PM
Dial Indicators chevyman992002 Garage - Tools 8 01-12-2008 08:30 AM
Speedometer dial in davidmiller1 Transmission - Rearend 7 02-27-2007 02:27 AM
finding the lift on my cam by using a dial indicator? Jacks77 Engine 13 09-13-2005 04:16 PM
