How did OEM's break in flat tappet cams??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2010, 07:49 AM
I'm about to put my first SBC together, and I've read many posts and articles about breaking in a new flat tappet cam, but my question is: How did GM do it when these engines were new? I can't believe they ran every engine for 20 minutes or more to break in the cam. Or did they?????
Old 11-19-2010, 07:56 AM
Irelands child's Avatar
They used oils with lubricity/wear additives like ZDDP plus didn't have excessive spring pressures like many of us use when we build a modified engine.
Irelands child
Old 11-19-2010, 08:41 AM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
I don't know for sure but I don't think the broke them in at all, the oem camshaft was much milder than a performance cam. Even the book 'how to rebuild a small block chevy' by D. Vizard, which is an older book geared towards a stock type rebuild, makes no mention of breaking in the cam.
Old 11-19-2010, 08:52 AM
That's interesting. I wonder if that's why older cars had engine break in guidelines for the first 500 miles or so. I wonder if this accomplished the same thing.
Old 11-19-2010, 09:02 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
At one time, at least some Chevy engines were run in for a brief time using propane or some such gas. I heard that this was no longer done, at least to the crate engines- but I have no confirmation of this, all hearsay.
Old 11-19-2010, 11:10 AM
here is a useful document on break-in : how and what
http://www.zddplus.com/TechBrief12%2...20Break-in.pdf
- Stephen
Old 11-19-2010, 11:28 AM
cam break in
First the oems used quality cam-blanks,I know several cam grinders(small operations) they tell me most mass cam suppliers buy cam blanks from china at 10 to 12 dollars@.they tell me a older core reground from oem stock is far better. I use a molly past on lobes and lifters always new,sensible spring pressure,they ar broken in with in 50 miles or less. or purchase a known cam with decent iron quality. cliff
Old 11-19-2010, 01:13 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Cams for as low as $14.00.
Old 11-19-2010, 11:13 PM
cam blank,is un ground cast cam.
Old 11-20-2010, 08:51 AM
BOBCRMAN@aol.com's Avatar
Back in the early seventies. I used to buy General Kinetics cams for $14.00 each ( orders of 10 min).
Hydraulic roller lifters on a hydraulic flat tappet cam?? hotroddin78 Engine 4 02-01-2010 07:26 PM
What type of cam has the least chance of failing? 4speed57 Engine 24 01-29-2010 04:46 PM
Can flat tappet cams really be used any more? eric32 Engine 19 08-20-2008 01:36 PM
Rollers or flat tappet in '89 350? LeadfootBob Engine 3 12-01-2007 11:07 PM
Best oil for flat tappet cam Steve B Engine 10 09-24-2003 07:26 AM
