Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to disassemble air ratchet?
Old 03-11-2009, 09:22 AM
DaSouthWon's Avatar
DaSouthWon DaSouthWon is offline
I put up the tools against$300
Lol, line inside a cardboard box. Make sure you make a note of how the vanes are installed and reassemble them the way they came apart or you may loose the seal and in turn power. there kinda like rings on a piston, they develop a wear pattern and putting them back in the wrong way does the same thing basically as putting new round cylinder rings in worn oval shaped cylinders.
