Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 10-24-2005, 07:33 PM
El Raton El Raton is offline
How to disengage transmission from block?
I have just removed the engine and transmission from my first project car. I removed all of the bolts that hold the transmission to the engine block. HOwever, I can't figure out how to separate the transmission from the block so that I can bolt the engine onto a stand. The transmission is a B&M Hydrostick and the engine a 1957 Oldsmobile 371. Any help would be greatly appreciated.
Thanks - JB
Old 10-24-2005, 08:13 PM
scottdavisson scottdavisson is offline
Hydamatic
I have only done this once, 20 years ago, but there were about thirty bolts through the flywheel that attached the torque converter. Check to see if there is a cover on the bottom of the bell housing that will allow access
Old 10-24-2005, 08:29 PM
Grey1961 Grey1961 is offline
re: How to disengage transmission from block?
I take it you meant three bolts and that is right, you will have to turn the engine over so you can get access to the bolts.. I think the torque converter would come out attached to the flywheel but it may need to turn first
Old 10-25-2005, 06:20 PM
Hydamatic
Mine was a 370 Pontiac, but there were many bolts holding the torque converter to the flywheel, I don't think the Torque Converter will just slide free,
Good Luck
Old 10-27-2005, 03:12 PM
Whippetguy's Avatar
Whippetguy Whippetguy is offline
You should definitely separate the torque converter from the flex plate before pulling the tranny off. The bolts should be visible when you remove the inspection plate. The tranny is held in position by dowels which can be stubborn, but a little wiggling and a few careful whacks with a soft faced hammer, if necessary should get it off.
Old 10-27-2005, 03:44 PM
redsdad redsdad is offline
Will I ever get it done?
If memory serves, the hydro didn't have torque converter. It had a fluid coupling. The front cover had the integral ring gear and bolted to the crank flange. There were a multitude of bolts which held the back cover/fluid coupling "pump" to the front cover. The driven pump was fixed to the input shaft with a large nut. So you have to remove the bolting which holds the back cover to the front cover.
Old 11-08-2005, 04:36 AM
IanRiordan IanRiordan is offline
Yup, many early auto's, US, Australian and European had a fluid flywheel not a torque convertor - no stator. Go easy, leave the hammers to the carpenters.
Old 11-08-2005, 07:59 AM
enjenjo enjenjo is offline
I believe a 57 will be a Jetaway trans. If it is, there are 4 bolts holding the fluid coupling to the flex plate. There are 32 bolts holding the fliud coupling together, but you don't have to remove but 4 of them. If it's a slant pan hydro, you have to remove all 32 bolts
Old 11-11-2005, 01:38 AM
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
Overqualified Underacheiver.
 M&M CUSTOM's barnstar
This is definitely one of those threads with a subject that can help the younger generations learn something about early hotrodding.
I'm always trying to learn, does anyone have any pictures?
Old 11-12-2005, 07:04 AM
56 Project's Avatar
56 Project 56 Project is offline
The flex plate has 4 ears that attach to the flywheel. undo those 4 nuts and the trans will fall out. This trans is very heavy(about 250#). Be careful 'cuz those flywheel teeth have sharp edges. My first car was a "57 rocket 88 with the 371 /4 barrel.
Old 11-26-2005, 06:55 PM
Jon's Avatar
Jon Jon is offline
Administrator
 Jon's barnstar
Wiki Edits: 3,646
Lightbulb Added to Hotrodders Knowledge Base
This discussion has been added to the Transmission - Rearend Discussions category of the Hotrodders Knowledge Base.
--For the main page of the Hotrodders Knowledge Base, click here.
--For more information on the Hotrodders Knowledge Base, click here.
--For information on becoming a Hotrodders Knowledge Base Editor, click here.
Write how-to articles with hundreds of other hotrodders. See 100+ articles, or start a new article.
Interested? Read The 8-sentence guide.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "How to disengage transmission from block?"
transmission oil type. TVR383 Transmission - Rearend 3 06-05-2005 08:28 AM
400 small block re"performance"build 78 monte Engine 2 04-19-2003 06:32 PM
Big Block/Small Block - Ford BigBlockBabe Engine 12 11-10-2002 03:01 PM
Block Painting do's and dont's Maverick Engine 20 11-02-2002 07:50 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
