Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to DIY Exhaust pipe bending
Old 04-03-2007, 06:01 PM
redsdad redsdad is offline
Will I ever get it done?
Last journal entry: Hood
Originally Posted by ChrisMiddleron
Ok thank you guys I figure I will just buy some muffler shop scrap bends some other random bent pipes and piece it together. If I cant get a couple of areas ill just take it to the shop.
Thanks guys,
Chris
You have to buy mandrel bent els. Most muffler shops don't do mandrel bends. When you cut through non-mandrel bent els, you will have an egg shaped hole, not round. You won't be able to line this up properly with the next straight or partial el. Mandrel bent els have a virtually round cross section through the bend. That will allow correct alignment with the next piece.
