How do '40 chevy coupe running boards bolt on? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2006, 02:11 PM
RodFather's Avatar
I smell like a hotrod!
Last journal entry: windshield
I am in the process of building a car that someone started....I am thinking that the frame had some kind of threaded bung so that you could attatch the running board....is that right? My frame is smooth (and painted), and I can't find where the running boards bolt on.
Old 10-13-2006, 02:33 PM
Marc Bitler's Avatar
Rodfather,
I also have a 40 business coupe I am building and the runningboards don't attach to the frame. Along the sides of your body, there should be three brackets that are attached to the inside rocker panels with a captive nut in them. They also attach to the bottom of the front fender. I bought an original car and the floors and rockers were so badly cancered that the attach brackets were gone. I had a devil of a time figuring out where, and how they attached. If you have a Chev's of the 40's catalog, they have an illustration that shows how they attach.
Old 10-13-2006, 02:36 PM
RodFather's Avatar
I'll check the chevs of the 40 catalog...I have new rocker panels, and did not see a captive nut. I have an idea now of what to do.
Thanks,
Brina
Old 10-13-2006, 02:43 PM
The new rockers won't have the brackets on them. They are purchased separately and have to be welded in place. If you bought new rockers, you probably bought outer and inner rockers. The brackets will attach to the inner rocker panel. They're a bit of fun to put in..........may be not so bad for you if you've done it before, but when I did mine, I hadn't.
Old 10-13-2006, 02:49 PM
RodFather's Avatar
The inner, and outer rockers were put on before I bought the car. The brakcets were never installed. I'll mount the board to the fenders and weld a bung in place. That should fix my problem.
Old 10-13-2006, 02:58 PM
Sounds like a plan. I just finished wiring my car, and installing the heat/ac, and fired her for the first time last weekend. Great feeling when things work like they're supposed to. She'll even pull herself.
I had my boards blasted a while back and POR-15'ed them and, oddly enough, just this last week, I was trying them on to see if they fit. I was a bit apprehensive but the brackets were where they were supposed to be. How that happened, I'll never know. Good luck.
Old 10-13-2006, 03:00 PM
RodFather's Avatar
Thanks, I too have drove my car around the neighborhood last week for the first time. Now it's all the small things.
Old 10-13-2006, 03:08 PM
I have done all the work on my car, except for the exhaust. I've never liked messing with that, and there are people who are masters at that, and I'll leave it to them. I think the most time consuming project I've had is putting in the electric windows. I eliminated the door vent windows and am putting in one piece windows. Have had problems getting it all to work, mostly getting the tracks square to the channels. Once I get them finished, and the door controls mounted, it's ready to final prime and block, getting it ready for paint. Maybe someday. I've been about 3 years working on it.
Old 10-13-2006, 03:12 PM
RodFather's Avatar
Yeah I have aways before I'm finished. This is an old pic. My glass is in, and I have Torq Thrust on it.
chopped, shaved, suicide doors, air ride.
Old 10-14-2006, 06:49 PM
there are brackets that bolt to the frame and then to the bottom running boards. They also bolt to the fenders.
Old 10-15-2006, 12:50 PM
Dant,
I read your post and had to go back out and look at my car. It doesn't have any mounts to the frame. My boards have the three brackets that bolt to the bottom of the boards. These three brackets bolt to captive nut brackets that weld to the inner rocker panels. The boards, as you said, also attach to the front fenders. In addition, there are about a dozen or so screws that attach thru the runningboard into the bottom of the rocker panel all down the side of the car. I don't know about all of the various bodies, but mine doesn't have any place for the rockers to bolt to the frame. It all bolts up okay, but personally, I don't think I'd want for a 200 lb. man to stand on them.
I have found that there was quite a few differences in the different bodies. According to Chev's of the 40's, one rocker panel fits all, but a fella I was going to sell my boards to (he had a convertible) told me that boards from a Master 85 coupe will only fit that car. He said he got his info from a 1940 parts manual he had, and there was another board for the other cars. A buddy of mine has a 1940 panel truck, and it's boards mount like mine do. The body is mounted on rubber, and the boards would have to move with the body, which they wouldn't if they mounted to the frame. I do know a lot of the old Fords' runningboards mounted to brackets that attach to the frame.
Old 11-04-2006, 06:39 AM
Last journal entry: 40 Chevy coupe
That's a nice old pic Rodfather. I'm also working on a 40 chevy coupe and have all the same ideas as you have described yours. Anyway you can post some new pics? What type of air ride and rear link system did you use? I am also going to try the 1 pc glass without the vent. I talked to a guy this past weekend at the goodguys show in Charlotte about his power window unit with 1 pc of glass and he told me he had a rough time trying to get it to work because the front of the door curves in at the front. He told me a friend of his mounted the power unit to a piece of metal and then moved the metal around until the glass fit the channel and worked properly and then screwed the metal off to the door panel. Any pics of any or all would be great. Thanks.
Old 11-04-2006, 07:28 AM
Bluepen's Avatar
Just a firefighter
Last wiki edit: How to title a hot rod
Last journal entry: New rear rollpan installed
Wiki Edits: 2
Rod Father
I know my '46 Panel is not the same as your coupe but the running boards mount in a similar way. The brackets come from under the body. You can see them in the pics.
http://hotrodders.com/gallery/showph...cat/500/page/2
Old 11-04-2006, 02:32 PM
ChasingJR,
I've removed the vent wings on my 40 coupe also, and ran into the problem of the doors being "bent" right where the vent and the main window meet. The 37's thru 40's did that. What I did was cut both the outside and the inside panels of the door and straightened them as best I could, then welded them back together. The outside panel is the toughie, since you don't want to force it to the point you wrinkle the skin of the door. You won't be able to get it totally straight, but when you put the window "whiskers" in, they will cover the small amount of bend that is left in the sheetmetal. I didn't have too much trouble with my power units, but did have to screw the top of the vertical shaft to the inside of the door to pull it inward a bit. Mine work fine. Of course, you have to weld new channels in the front and rear of the door. You'll have to cut the old window frame to allow the new vertical channels to be at the extremes of the window opening. My kits said I wouldn't need side (vertical) channels, but that was BS. Windows would wobble, and you need a guide in to the window opening. My problem was getting the window lift channel perpendicular with the side channels. You'll have to weld bolts on the inside of the side channels and slot the door inner panel so you have adjustment of the side pieces in and out and fore and aft. Hope I haven't confused you.
Marc Bitler
Old 11-04-2006, 03:11 PM
Marc, thanks for the information. I still have this ahead of me and any info. I can get from someone who has already done it is helpful. The way you have explained it is clear. Thanks again and thank you RodFather for letting me get this info. on your thread.
Chevy 350 Crankshaft bolt removal 75gmck25 Engine 11 03-14-2008 06:27 AM
1940 Chevy Coupe CHASINGJR Introduce Yourself 9 11-10-2006 06:07 AM
'40 pontiac coupe gahi Hotrodding Basics 1 10-16-2004 04:52 PM
35 Chevy 3 Window Coupe paulm Body - Exterior 14 05-08-2003 12:37 PM
40 chevy coupe rpvette Body - Exterior 3 01-22-2003 05:02 PM
