how do approach interior metal rust? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2009, 08:58 AM
this is the inside of my 74 soa nova
Old 06-12-2009, 11:38 AM
I can't see the pics, but if the metal is rusting on the inside, it's gonna rust through.
After grinding and treating with acid, I'll bet you find a few pinholes. Pinholes = the end of the road for metal.
After replacing the metal, you must find out how the moisture got back there in the first place, and rectify that situation.
Old 06-12-2009, 06:02 PM
I like a wire brush on a drill for areas like that. A wheel style for large areas. A cup style for smaller areas. For hard to reach areas you can try steel wool/navel jelly. You can also knock off the loose stuff and apply POR15 or Rust Encapsulator or similar product of your choice. It took 30+ years to get that small amount of surface rust on it. With a little elbow grease and some POR15, it'll last a lot longer than you will.
Old 06-12-2009, 07:31 PM
yeah ive heard great things about por 15 thank you all for info
Old 06-12-2009, 09:06 PM
I'm not so sure about the rusting thru byu the looks of that. I'm no expert, but I had removed the headliner backer etc in my car and over time it had gotten rusted, kind of like the looks in the pics, but not bad at all really - no pits or deep rust, just a fuzz like from condensation on the roof. I was jus lookinn at it last night. On mine, I'm thinking about some of those 2-3" pads that are for cleaning, then epoxy. I know people have used POR15 but the more I read about it, the more I don't want to use it - never have. I think now, after having spoke with guys who swear by epoxy that it's just your best bet. Maybe one of those Pro guys will tell you what to do, and as importantly, what not to do.
Old 06-12-2009, 09:20 PM
why dont you wanna use por 15 deez?
Old 06-13-2009, 01:39 AM
I think the question is: how clean are you going to be able to get the metal first? It's my understanding that epoxy (or any other basic paint) over any rust (surface rust, pits, etc) will fail with time. If you can't get rid of all the rust, I wouldn't cover it with epoxy. Similarly, I don't apply POR15 over pristine metal, that's not how it's supposed to be used. Fortunately, that area won't be exposed to much moisture so which ever way you go, it's not likely to cause much problem in the future. I've never had POR15 fail me when used appropriately but I don't like painting over rust. I'd get rid of whatever rust you can. Whatever you can't get (in seams, in tight corners etc) I'd dab on POR15 before it dries completely, mist the POR15 with a quality primer and topcoat everything with whatever product you want. To be honest, if you get the metal real clean, a spray can enamel should provide adequate protection in that area.
Old 06-13-2009, 08:50 AM
bobjob's Avatar
rustolium ????
Old 06-13-2009, 07:20 PM
Yeah, I couldn't see the pics and imagined it was something along the lines of what I usually see, which is ugly.
I would clean, wire wheel and sand, and POR-15 that. Use the acid, keep it wet, scub the acid with a small stainless steel bristle brush, then POR-15 it and forget about it.
Approach to surface rust repair? grancoupe Body - Exterior 4 10-20-2008 02:16 PM
65 f100 and the battle of rust. z chrome rust defender? 65fordguy Body - Exterior 3 08-03-2008 04:16 PM
Rust inbetween Double Seem Questions Advice on ATTACK Plan fcastro Body - Exterior 3 01-21-2008 11:20 PM
Rust Spots WildBill Body - Exterior 3 11-09-2007 06:22 AM
Rust Dissolver versus Rust Convertor? 66GMC Body - Exterior 9 11-06-2005 05:48 PM
