just hold the brake and feather the throttle like this:
http://www.youtube.com/watch?v=HCaj2gFXnfU that was my truck with a 350 and a q-jet,mines got a 4-speed though. |
you should still be able to do a burnout with 3.08's are you leaving it in 1st gear or tryiing it in drive? mine had 3.08's in that video.
I am leaving in drive. Shouldn't it automatically be in low taking off? It feels like it shifts while I'm holding the brake. I tried rolling backwards and hit the gas yesterday and got it to let go for a short distance.
Midnight Sun Street Rod Association |
[QUOTE=Mertz]I am leaving in drive. Shouldn't it automatically be in low taking off? It feels like it shifts while I'm holding the brake. I tried rolling backwards and hit the gas yesterday and got it to let go for a short distance.[/QUOTE]
I won't take too many of those and the drive shaft will drop out of it or the diff will let go. |
Yes I know this is not good practice but I wanted to see if it would work. I barely had it rolling backward when I put it in gear and hit the gas. I know now how those rice burner make those J burnouts that look like they were going backward while doing a burnout then forward leaving a track like a J.
The 50 is all in with mechanical and vacuum. It is not likely that I have the vacuum advance when I step on it since it goes to almost zero but the mechanical is picking up with the rpms. If I hold it at 3000 and it has vacuum and mechanical advance it is at 50 which I understand is correct for a 350. I am running the vacuum advance off manifold vacuum. |
If you want to do a hairy burnout, do it like the pros do, start on water. it will save on equipment. Pull it down into low, pull the back wheels into a good wet spot, power brake it til the rpms hit about 3000 and let off the brake and bury the throttle. You should be able to fry the tires pretty good!
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain |
I don't think I am ever getting it to rev to 3000. It seems to bog down when I power brake it. The main reason for wanting to do a burn out is so I know I have enough low end torque to pull my 5000 lb trailer. I figure if I can break the tires loose I should be good on torque. I figured that with 1.5 roller tip rockers, Edelbrock 2101 manifold, ceramic coated headers with dual flow through exhaust and H pipe, rebuilt transmission with stall kit, timing at the optimal 36 initial + mech, MSD Ready to Run distributor, new Moroso spiral core wires and dailed in qjet (couldn't do it with the 1406 Edelbrock either). I think I should be at about 290 hp and should be able to break them loose. I have been trying to build low end torque and it would appear that I haven't been successful if I can't do a burnout from a standing start.
now dont tell me you've never just wanted to do a big smokey burn out |
| just a quick video of my 66 in the car show today (burnout) | kc0kfg | Hotrodders' Lounge | 3 | 10-07-2008 05:02 AM |
| Burn Out Burnout Wawaaaaa Burnout Burnout!! | Rob Keller | Hotrodders' Lounge | 13 | 01-20-2006 12:52 AM |
| Burnout clips | Neophyte | Hotrodders' Lounge | 5 | 12-27-2005 08:08 AM |
| Tooo long of burnout??? Lower Gears??? | 63wagon | Transmission - Rearend | 11 | 08-08-2004 02:13 AM |
| Burnout question. | speedingpenguin | Hotrodders' Lounge | 28 | 03-26-2004 10:11 PM |
