How do I add a wire to my fuse box?
I have an 84 C10 that I'm trying to wire up an electric choke to, and I would like to run it off my ignition. I thought there was a way you could pull the front panel with the fuses off to get to the terminals underneath, but I don't know how to do it. I don't want to go gung-ho on it because I'm afraid I might screw up my fuse box. Can anyone tell me how, or if this can be done? Thanks.
The fuse panel does split in half if you remove the screws and release the clips, but I don't think you need to do that.
There should be several terminals in the fusebox that are designed for adding more circuits. Some are used by factory options (for example, the lights on buzzer option, or aux fuel tank option), but others are usually open. For an electric choke you want to find an ignition switched power source, and then use it to activate a relay under the hood. The activation side of a relay will put such a small load on the fuse box that it doesn't really matter what circuit you connect to for activation. The relay under the hood can draw its power for the choke through an inline fuse that is directly connected to the power junction on the firewall (next to the brake booster). Bruce |
Bruce has the suggestion for you.
If you are not familiar with how a fusebox is wired or put together, some interesting things may happen that will not be pleasant. Entertaining to us-----but a PAIN IN THE ***** to you If your truck has any options at all,it is likely that you can use an existing grommet in the firewall to poke your wire thru. I just disassembled an 82 C-10 and removed all wiring. More holes in that firewall than swiss cheese. And most all of those grommets were just normal grommets glued in place on the wiring harness. For temporary use, a regular male spade connector can be used in any of those unused "IGN" ports on the front of the fusebox (About 3 of them), many cars have connectors to allow more than one circuit to be used in each port. For permanent connections I would suggest the factory type connectors to plug into the fusebox----it might be noted that these things are keyed, so that a connector body that is intended for an ignition source will not plug into an ACCY, or BATT port. Might find the connectors at a junkyard, or give American AutoWire a call They sell them----Fuse box taps, a set of 10 or 11 for $15. |
I was just going to post use the "IGN" and a spade connector.
You don't have to cut anything and its easy to remove. Just add an in line fuse and your good to go. |
How would you wire it to the Alternator? Mine has three wires going to it, two are on a plug that plugs into it and the third is on a small stud with a nut. The one with the stud and nut is hot so it wouldn't work there. The other two wires on the plug are red and black.
It goes to the stator connection, the way I did one fairly recently in an S10 V8 conversion was to just use the alternator as a power source for a relay and powered the choke from the battery. This is not necessary however because the choke draws very little power and powering directly from the alternator works just as well, still some had rather use the relay as did the owner of this truck.
Another way to do it, and GM did it this way also, is to simply add a pressure switch and use engine oil pressure to switch power to the choke from the battery eliminating any alternator connection at all. Either way works just fine and either way is not at all hard to connect, both of these connections will eliminate the problem of the choke opening too early. |
| Wire guage for 50 amp fuse | heyjude076 | Electrical | 2 | 05-19-2008 08:58 AM |
| Roll Bar Install Advice | Mustangsaly | General Rodding Tech | 12 | 12-02-2007 08:33 AM |
| Idiot Proofing My Trailer Wires | Rob Keller | Electrical | 41 | 05-14-2007 07:32 AM |
| where's the fuse box | nknfuts67 | Electrical | 1 | 12-12-2006 07:01 PM |
