Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How do I bend/form luan plywood?
Old 02-15-2013, 11:27 AM
5window 5window is offline
Originally Posted by timothale View Post
In the 70's I built 4 model t speedsters, I had access to a school metal shop, so I made mine from sheetmetal, At the same time when I was in N Calif a guy was bending 1/2 in boat plywood enough to make the curved seats , Idon't know where you can get the material today, but as Dan said you need a good form. My nephew in calif was making skim boards that kids use at the beach, he had forms and a big frame made from 4 X 4's and glued and laminated the thin ply and a 12 ton Hyd jack to press them.
That sounds like an awful lot of work/equipment to form a couple of curved panels to fit the rear corners of a chopped A coupe. but,thanks.
