Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How do I bend/form luan plywood?
  #23 (permalink)
Old 03-15-2013, 02:55 PM
sportcoupe sportcoupe is offline
Last journal entry: door trim
Originally Posted by 5window View Post
I did a search-it's probably here but i missed it-
I have found some 1/8" luan plywood (as opposed to PVC foam board) that I would like to use for the interior panels in my Model A (to be covered with vinyl). I am going to need to bend and form them to match the curvature at the rear corners of the cab. What's the best way to form them and to get them to stay formed?
Thanks
trying to bend plywood is not easy, the best way is to make a form and use thin veneers which can be bought on Amazon or some lumber yards, spread a thin layer of glue on each veneer until the desired thickness press it into the form clamp over night then trim to fit. I just went out a bought a piece of sintra sign board to do the same thing in my coupe door panels. good luck, SC
