How do i change color - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-30-2004, 07:01 PM
New Member
How can I change the color of my 96 Dakota Door panels, they feel like plastic..
can i use vinyl paint? i do not want spray can.. its grey now i want them in blk, and tips or tricks?
thanks
Don
Old 12-02-2004, 12:36 AM
BradOlive's Avatar
New Member
Vinyl or ABS or ???
You can use vinyl paint - but only if it is vinyl - it will peel off of anything else.
Your best bet is to get krylon plastic paint and primer - and spray it - yes, I know you don't want spray, but that gets you the best look - factory look. Otherwise you will get splotches from stains or brush marks from liquids.
It helps to know the material - and then get the right paint. In a high use area you will want to follow the directions to the T and do several coats - letting it cure between and after coating.
Old 12-02-2004, 12:41 AM
New Member
ok thanks, would dupont or PPG make this paint so I can spray it with a GUN..
Old 12-02-2004, 01:02 AM
BradOlive's Avatar
New Member
PPG
It has to have a special base to adhere to the plastic. The same paint they use for bumpers - so if you have ever shot a newer car you get both mixes -- the krylon stuff is cool though, it really looks like the plastic is colored and not painted. I haven't tried shooting bumper paint on a textured door panel but it should work - just get the coats real thin.
PPG should have it - no problem. Just get the right solvent to thin it and try it on the back first!
Good luck!
Old 12-02-2004, 08:42 AM
New Member
OK thanks Brad, you been a big help........
have a nice weekend
Old 12-11-2004, 07:27 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
You will need a primer for the bonding of the paint, plus a clear coat is recommended.
http://www.eastwood.com/shopping/sea...interior+paint
has all the paint for plastics.
Luv the smell of NITRO in the morning.
Old 12-11-2004, 09:34 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
tips or tricks?
They make a black car wax to fill in scratces. You might try this also.(it takes a lot of buffing)
