Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - how do i change the resistance wire that runs to my dis?
Old 12-23-2002, 11:55 PM
Marcus Marcus is offline
You have to replace that resistance wire with a 10 or 12 gauge wire so that your distributor will get a full 12-13 volts it requires otherwise you may damage the module or at the very least get inferior performance. I just pulled the old wire out at the firewall and replaced it with a 10 gauge wire.
