Doing it yourself can be done and a good thing to learn, this is electrical basics at its finest. When you say generator I think a 6v system, but I assume this is 12v system and will proceed with it as a 12v.
A proper battery tester is a better way to test because you are able to load the battery and alternator as needed. You can still load the system but will not have the control like a tester will provided. Many ways to skin a cat, this is how I would do it without a tester.
You need a voltmeter.
Battery cable ends clean.
First test the battery, it all starts here. A bad battery will throw off the readings of the alternator. Measure across the battery posts, 12.6V is a fully charged battery. If it is under 12.0V charge it up. Then keep the leads on the battery and turn key on engine off then turn on heater, lights, wipers and radio as available for ~3mins. Battery should not drop below 10.5V. Then turn the key off and all accessories off and measure battery voltage after letting it sit for 5 mins. The battery should recover back to at least 12.0V +/-.6V if it drops below 10.5V during load test or 11.4V on recovery then I would suggest testing the battery with a battery tester at this point, my preference is a carbon pile loader but the testers like a Midtronic are good as well.
Once the battery is verfied, the alternator is much easier. This is just a basic DC voltage alternator test and will not test for excessive AC voltage. This will tell you if it is charging. Start the car and measure the voltage at the battery, 13V at the very minimum 16.5V maximum and rev engine to 1500rpm. If under the alternator is not charging and likey caused of a bad alternator but if PCM controlled then the feild circuit may be the cause. If higher than 16.5V then the issue is a regulator as the alternator can make the juice but nothing is regulating it. If alternator is internally regulated (most vehicles '77 and later with the exception of PCM controlled), replace alternator. If externally regulated, the regulator needs to be tested, but probably a regulator issue. If alternator is between 13V-16.5V then the system needs to be loaded, turn every accessory on, lights, wipers, heater on high, radio, everything then rev engine up to about 1500 rpm and read voltage, same-same as above as far as specs and where to go if out of specs.
Do you have a problem right now? or....?
Hope this helps
