How do I determine what crankshaft I have - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2012, 11:21 AM
I have two crankshafts here for a 350 I am rebuilding, both are stamped 39822442 on the shaft itself, on the end of one the number 1355 is stamped on the other nothing. The stamped unit is a GM 9, the unstamped is GM59. Is there any way to determine what these units are or which may be better than the other to use for the rebuild.... I am new to this to restate the obvious. Thank you for any and all help.
Old 02-25-2012, 01:51 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
That's too many numbers, and I can't find a 398xxx crank listed. Are you sure it's not a 3932442? That would make it a 267, 305, 350 cast, medium journal 3.48 stroke crank. Look here.
Semper Fi
Old 04-16-2012, 07:48 PM
hmm may need better glasses...
Yes the number was a three when I cleaned it up a bit more I could read it. Thank you for your help
How to determine which alternator to use Bob 33 coupe Hotrodding Basics 6 02-27-2011 01:10 PM
how do you determine anokha Engine 6 05-21-2008 02:17 PM
How can I determine if? barnym17 Body - Exterior 8 05-10-2008 08:56 PM
how to determine the right ratio Ratoflic Transmission - Rearend 4 07-07-2007 05:04 PM
Need to determine a car denk General Rodding Tech 1 12-15-2003 04:44 PM
