how do i disconnect neutral safety switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2011, 03:38 PM
i have a 65 chevelle. we converted it from a column shift (originally powerglide) to a floor shift with th350. i am having starting issues (acts like battery is dead) but battery is good. thinking it could be neutral safety switch in column (volt guage drops to 0 when turned to start) otherwise at 13-14 volts.
can anyone tell me how to find and disconnect the neutral safety switch
hoping that this is the problem. please help
Old 08-27-2011, 04:46 PM
LATECH's Avatar
Last journal entry: New Gas Tank
It is the purple wires on the top of the steering column, under the dash.
You can make a jumper to test it with,doesnt sound like your problem but nonetheless . Jumper the 2 purple ones together and there you go.
Old 08-27-2011, 08:39 PM
Your problem is not the neutral safety switch, key being the V meter going to 0. The problem is age old GM of poor contact in the battery lead connection to the large post on the starter, or a poor ground. If your battery is in the trunk and you are running your bat ground to the frame instead of a # 2 wire to the starter mounting bolt, it will have the same symptoms. Having run an auto without a N safety switch for a while, I would never recommend disabling it.
Trees
Old 08-28-2011, 06:27 AM
EOD Guy's Avatar
Your new floor shift should have provisions for a NSS, I would extend the purple wires over to the new shifter. That's what I did when I converted from column to floor. Sounds like no big deal bypassing the NSS.......but after you forget and start it in gear and it takes off on ya, you'll see the light and hook it back up.......don't ask me how I know this......lol
Old 08-28-2011, 10:02 AM
Love This Forum
Thanks Guys For The Info. I Love This Forum. I Am Going To Wire The Nss To The New Shifter. Sounds Like I Have A Connection Issue As Well. Battery Is In Stock Position Under Hood And Grounded To The Alternator Bracket Currently. I Will Ground It To The Starter Mounting Bolt As Well.
Could I Also Have A Solenoid Problem? Reading Alot About Heat Soaked Starters/solenoids.
I Am Learning As I Go And Appreciate Any Info That You All Have That Can Help.
Thanks Again
Old 08-28-2011, 04:05 PM
EOD Guy's Avatar
There is a bolt hole on the pass side head, just behind and below the alt (at least my setup) that's a very convenient connection spot.
Old 08-28-2011, 04:10 PM
EOD Guy's Avatar
Key on the column or dash, I don't know to much about the Chevelle. If it is column keyed, do you have a connector of wires (from the column) bolted to the lower end of the column? If you do, that could be part of your porblem..... that is the actual Acc/Run/start switch and it sildes for adjustment. Try unbolting it from the column and use a small tip screw driver slide it to the start position and see if that fixes your problem
If it is dash keyed... disreguard the above
Old 08-28-2011, 04:40 PM
Dash Key
It Is Keyed On The Dash .. If The Starter Connections Are Not The Problem I Will Check The Ignition Switch
Thanks
Old 08-28-2011, 07:15 PM
EOD Guy's Avatar
Mine had a few issues with juice...... when I checked the ing switch, it was hacked and spliced beyond belief....... ended up replaceing the main feed wire and undoing 30 years of screw-ups!
neutral safety switch rusty duck Electrical 6 11-30-2010 06:29 PM
Neutral Safety Switch Help johns79z28 Electrical 7 03-08-2008 02:40 PM
Neutral safety switch Don Lyon Transmission - Rearend 2 02-16-2007 07:51 PM
? about my neutral safety switch in C10 Streetmaster Electrical 4 08-30-2005 01:41 AM
neutral safety switch? akm General Rodding Tech 7 08-07-2003 04:18 AM
