How do I find out if a valve is stuck? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2009, 02:06 AM
can I remove my valve cover and turn on my truck(1990 k1500 350 5.7l tbi ) or maybe handcrank it and what r the valve cover bolt torque specs? thanks guys.
Old 12-16-2009, 02:35 AM
DoubleVision's Avatar
Valve covers don`t torque, you just snug them. I would do the hand crank idea, as when it`s running the motions maybe too fast for the eye to detect.
You could also try a compression test on the suspecting cylinder.
Old 12-16-2009, 09:53 AM
Hook up a vacuum gauge, every time that valve should have closed as commanded but didn't there'll be a drop in vacuum which will then recover and repeat on the next cycle.
Bogie
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 08:31 PM
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
Reducing Valve Lash on Solid Roller - Is It Ok To Do? leejoy Engine 13 12-19-2008 10:11 AM
Stuck intake valve jdoole3803 Engine 2 08-26-2006 04:11 PM
Stuck Valve Daved Engine 4 07-16-2003 07:39 PM
