How do I fix this? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2007, 07:17 PM
Silverback's Avatar
Boost Retard
How do I fix this?
I believe that itís urethane (someone correct me if Iím wrong), itís a piece of body cladding (fits along the bottom of the quarter on my í87 TA) that is cracked in the front where the pocket in the back that holds the strip that the mounting studs are attached to ends.
What kind of repair will hold this stuff together? How about something that I can get in small quantities since this is the only damaged plastic that I see on the whole car/project.
Old 04-10-2007, 08:13 PM
Urethane isn't to tough to repair, check out some of the repair information on the fusor website. You'll have roughly $50 in materials from abrasives to plastic repair material and primer, etc...
Old 04-10-2007, 09:39 PM
Silverback's Avatar
Boost Retard
Well, Iím coming to the conclusion that Iím not sure what it isÖ it does have a yellow inside like the stuff that is usually identified as urethane, but no labels or logos inside, at least not that I recognize. The only thing inside is what I assume is a factory PN and build code:
10030539
GAV. 1
Z 7743
F U R
Bob, thanks for the answer but man, thatís not what I want to hearÖ sometimes when you get lucky you can snag most of the bottom moldings for $50-100, itís hard to swallow that kind of money to fix a 1Ē long tear. Like I know that Evercoat makes an adhesive that will work but last I checked it was like $40, especially if the tube comes with enough in it to mold a whole new part out of it or make like 600 of these repairsÖ
Old 04-11-2007, 07:40 PM
Silverback's Avatar
Boost Retard
Well crud, I donít believe that I did that, hard for you guys to comment on something that you canít see huh?
Here, check these out, just multiple shots from different angles:
http://mpikas.midimonkey.com//images...7-03-30_04.jpg
http://mpikas.midimonkey.com//images...7-03-30_05.jpg
http://mpikas.midimonkey.com//images...7-03-30_06.jpg
http://mpikas.midimonkey.com//images...7-03-30_07.jpg
Can I fix damaged corvette door myself? LouisvilleLT4 Body - Exterior 23 09-29-2006 10:44 PM
POR 15 to fix Cancer on Steel??? djjc76 Body - Exterior 16 01-16-2006 11:46 AM
How to best fix cracking arm rest Wmarden Interior 2 10-28-2004 11:28 PM
Insane fix for press-fit pistons 87442lover Engine 1 12-16-2003 09:20 PM
Posi-trac Experts (If it ain't broke, should I fix it?) Axelrod Transmission - Rearend 3 05-21-2003 05:23 PM
