Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How do I fix this rear disc brake problem?
Old 06-08-2013, 12:14 PM
hduff's Avatar
hduff hduff is offline
Fix it until it breaks
Last journal entry: Matt got a new motorcycle.
I'm having some braking problems and then I discovered this (I did not build this car).
Left rear
Right rear
It looks like the calipers are oriented correctly, but the parking brake cables on the right rear are working "backwards" and will never keep the pads adjusted. I believe these are Caddy calipers, but I'm not certain (diff is a Chevy Nova 10-bolt). It seems that I just need a set of parking cable brackets like the ones on the left rear, but I'm not sure what to get.
Advice?
