How do I fix a run in black signle stage? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2008, 09:37 PM
How do I fix a run in single stage?
I painted a truck today with Kirker single stage urethane enamel(solid black). Got a couple runs in it and am wondering how to fix them in a single stage system.
Also, I had planned on clearing it for added gloss, but didn't want to spray the clear until I fixed the runs. How do I go about clearing it now (after I fix the runs). I assume that I will have missed the clear coat time frame. Can I scuff and then clear or will I need to scuff, shoot more color and then clear?
Old 07-16-2008, 01:00 AM
Countilaw's Avatar
Cox Custom Cars
You can take a scraper, the kind that you use to scrape stickers off glass, and scrap the bulb of the run off. The wet sand with a block the rest of the run out.
I've used Kirker before, and have found that you can recoat two to three days after application with no problems.
Any longer than that, you will have to scuff. If it were me, I would wet sand with 600 wet and then shoot the clear.
Old 07-16-2008, 11:14 AM
Silverback's Avatar
Boost Retard
Could you use a fine scotch bright pad to scuff before clear? Seems like it would be quicker and more consistent then 600wet, but I'd worry about it leaving 2 coarse a finish.
Old 07-16-2008, 11:59 AM
need strog32 chevy front doors
Last journal entry: Tbd
where are the runs?? I never heard of applying clearcoat over a single stage paint, can you do it.
You can scuff and buff, I've got no expereience with buffing but it can be done from what i've seen
or you can scuff the whole are with 600 grit and spray a last coat of single stage.
First paint scheme for '59 Caddy by me Nightrider Body - Exterior 54 07-05-2005 02:27 PM
Black Paint Prep Ron M Body - Exterior 1 08-22-2004 12:38 AM
verbal description of raven black as compared to black Dubz Body - Exterior 5 02-24-2004 12:01 PM
Black is black? dh79 Body - Exterior 5 02-07-2004 04:38 AM
