Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How do I get 500 Hp out of a 454 with peanut port heads?
Old 01-08-2012, 10:21 PM
topwrench's Avatar
topwrench topwrench is offline
Last journal entry: fish carb
Originally Posted by painted jester
With me its always rear wheel horse power that pops into my head (probably because I ran rear wheel Dino's And did high speed tune ups on r.w.dino's)! Its hard to lean over a hood at 80 miles an hr on a drag car LOL
Its funny, people buy Big cu inch monster crate engines thinking their 500 horse power is guaranteed because of the adds and litrature says they were dino tested ! Then they bring em in and find out they have 275 hp at the rear wheels!! A lot really get upset and yell at me After doing quite a few crate motors that were installed in vehicles they average a little over 1/3 less hp at the rear wheels compared to their advertized brake hp!
But then you get the young guy that built a strong mouse motor himself did it right and its pullen 275 hp at 6500 rpm and climben the look on his face makes my day.
people dont understand you can put that same 275 hp mouse into another car and only get a reading of 210 hp at the same rpm or change to a lighter rear end dope and gain 3 hp! The big one I see most are the people putting in high volume higher pressure oil pumps and their oil pressures reading 90# at idle hot! they just dont understand how much hp and torque it takes to power that pump. Just changing fans can give your eng 5, 10, or more usable hp
I didnt have to write all that! I already know cobalt knows this and a lot more! but some visitors may not
Given the same H.P. weather.Flywheel,Gross or rear wheel B.M.E.P. decreases with increasing displacement.And B.M.E.P.plays a great role in the durability of any engine weather S.I. or C.I.
I know this statement is arguable with how you get to the same H.P. but it is generally true!
Decreasing internal component friction by the use of lighter oils always gives a small increase in H.P.
Removing ancilliary loads also gives increases in H.P.
Dyno adjustments,ambient temp,exhaust header internal condition(rust or carbon build up)can also affect the readings
I know Im splitting hairs here.Ive never seen two different dynos give the same readings.
Im not bashing dyno tuning,I think its a great thing!
Ive personally seen a S.B. load up to 800 G.H.P. at 9200,n that was at 209 C.I.D.with a little less than 2 ATM of boost!
