Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How do I get 500 Hp out of a 454 with peanut port heads?
  #30 (permalink)
Old 01-13-2012, 05:28 PM
matts37chev's Avatar
matts37chev matts37chev is offline
& matts38chev
Last journal entry: Try again
Originally Posted by ethn_bert
Ditch the peanut ports and go for some closed chamber heads and you can get away with that cam and factory flat top pistons. Otherwise you will need some domes and serious work on the peanut ports. That will save you a couple hundred dollars
Originally Posted by matts37chev
I also, have based my engine build on that series of articles (it helped me choose a cam)
but I was a little farther into the head and cam upgrades that they did in later articles, with the same motor.
I dont have the peanuts
I have some 781s that have been cut for larger valves
I used the article cobalt posted for my Nova
However I ended up running 8 to1 compression In order to run 87 octane.
I was asking how your 8:1 comp. works with the XE 268 cam that was used in the build, in the magazine article
but you used a lot smaller cam
