How do I get 500 Hp out of a 454 with peanut port heads? - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 04-04-2013, 05:08 AM
Originally Posted by Hogg View Post
Yes, Europe usually uses Research Octane Number, while North America uses the average of the sum of MON and RON or (RON+MON)/2 Reaserch Octane Number and Motor Octane Number.
Our Sunoco Ultra 94 RON+MON/2 is much higher in octane than 96 RON octane.
peace
Hog
How high a compression ratio can you run with the sunoco 94 with normal distributor advance settings? ( I remember guys putting sunoco 260 in their volkswagen beetles for more imagined power,later burning the valves of course)
  #47 (permalink)
Old 04-05-2013, 09:41 AM
I couldnt even hazard a guess.
Anyone else?
peace
Hog
The Following User Says Thank You to Hogg For This Useful Post:
yankee phil (04-06-2013)
  #48 (permalink)
Old 09-30-2013, 05:10 PM
Originally Posted by ucarlg View Post
Hi, I recently bought a stock motor home 454/ th400 combo for my 1970 c-10. I would like to get about 500 hp. Can someone help guide me in the right direction?
The peanut port heads will support over 500 hp withe right parts, thats without any port work. Only a casting flash clean up on the ports. A pro comp air gap dual plane or a Edelbrock air gap performer rpm. A good cheap cam would be a summit k-1303 w 540 lift 238x248 duration at 0.50 lift 114 lobe seperation. good aluminum 1.7:1 ratio roller rockers. 5/16 harden push rods, 9.0:1 compression. Headman 1 3/4" primary pipes, 2 1/2" collectors and pipes with good free flowing with turbo mufflers. HEI distribiter with mechanickal advance all in by 2200 rpm. No vacuum advance. 65000 volt coil. over 500 hp at 5500 rpm, and over 550 ft lbs torque at 4200 rpm. This is all computer estamated given the parts used. So I threw in all the part's that I thought would make 500 hp and sure enough after a couple of different combos with computer hep made the said power. So that artical in super chever with the 446 hp at 4900 rpm is a bad *** street engine no matter how you slice it.
  #49 (permalink)
Old 10-06-2013, 12:23 AM
vinniekq2's Avatar
mistakes
I think your mention of 1 3/4 header pipes is not correct,same with 2 1/2 collectors
Could you show the math on getting 500 HP from peanut port heads? which ones?how many CFM in stock peanut port heads?
are you sure those cam specs are correct for a mild engine?
why is the full spark advance in at 2200 rpm?
  #50 (permalink)
Old 10-06-2013, 12:32 AM
sunoco 260!?
The engine was probably was getting close to burning a valve anyway maybe running lean and then you ran the sunoco 260. TheY AIN'T going to say nothing!?!? Your are not the only one that has gotten shafted. so I hope you get something for your misfortune
  #51 (permalink)
Old 10-06-2013, 04:38 AM
you say you know more than me, so why ask me!?!?!?the pp # 360 no port mork just the way gm manufctored them. the flow data is. Edelbrock Victor intake 750 dp holley. The cam specs are 560/580 split 248/254duration at .050, 110 degree lobe seperation. The dyno headers were 2 1/4" primary. They claim that with the need of bottom and mid range torque that the 1 3/4 headers are fine as long as you keep rpm at 5500 rpm. Actual hp and torque 512 hp at 5800 rpm and 514 ft lbs torque at 4800 rpm I hope this helps
Int. exh
100 54 45
200 124 102
300 195 118
400 216 141
500 235 157
600 236 168
  #52 (permalink)
Old 10-06-2013, 05:27 AM
500 hp peanut port heads.
If you l@@k I,ve already answered this same question
  #53 (permalink)
Old 10-06-2013, 05:35 AM
LATECH's Avatar
Vinnie is being helpful. Havent you ever heard of the "Devils Advocate" ?
Lose the attitude and learn something. He is not badgering you, he's trying to help.
Fact is stranger than Fiction
  #54 (permalink)
Old 10-06-2013, 12:44 PM
sarcasom
I do not like sarcasm for help, I don't need help that talks to me like he talks to me.
  #55 (permalink)
Old 10-06-2013, 02:30 PM
LATECH's Avatar
Relax....
No one is dissin you. He merely said "I Think" ... Not... "You are" if you read it correctly.
That does'nt translate to "You are incorrect".
You are getting uppity for no reason.
Allways room here for a healthy debate.
Besides the flow on those heads looks weak for a 500 HP mill. Just sayin.
  #56 (permalink)
Old 10-06-2013, 03:16 PM
techinspector1's Avatar
Wiki Edits: 326
You're ugly and your feet stink and I don't like the way you hold your mouth when you talk. Try that on for size.
  #57 (permalink)
Old 10-06-2013, 04:28 PM
Originally Posted by LATECH View Post
Relax....
let it go man you act like your still a kid over nothing that concerns you. The flow of a head and a cam profile go hand in hand. Small heads bigger cam higher rpm. More head flow less cam timing.John lenginfelter made over 600 hp from peanut port heads. Using a 502 bbc. He opened up the intake port to match a single plane intake. With a gradual neck back down to the pp's size. Added bigger valves. Thats it to the heads. So 500 plus hp with a 454 is nothing new.
  #58 (permalink)
Old 10-06-2013, 04:43 PM
LATECH's Avatar
[QUOTE=arless;1816017] let it go man you act like your still a kid over nothing that concerns you. [QUOTE]
Being a Moderator there is plenty to concern me. I am no kid.
Youre messin with fire
Lose the attitude sonny.
  #59 (permalink)
Old 10-06-2013, 05:02 PM
LATECH's Avatar
Building a BB Chevy. I want 500HP
Good reading here. Especially Firestone' , F Bird and Techinspector post.
  #60 (permalink)
Old 10-06-2013, 05:19 PM
jokerZ71's Avatar
Wrench Turner
Arless,when post incorrect info wether intentionally,or,even just from not knowing any better,someone here is gonna call ya on it.Even if not necessarily incorrect,but,anything contrary to what makes good sense.Some of your posts have been,for lack of a better word,unbelievable.Not everyone has to agree & often times we don't.Some of us have different ideas & can think outside of the box.However,when you make the claims,you should be able to back it up somehow,someway.You don't offer anything except wild exaggerated claims & then seem to get upset when someone questions you,or,asks you to validate or show some proof.It seems that you have some type of simulator program your playin with & posting the results here as actual builds & experience.IDK.These builds prolly only exist on your hard drive.If that's the case.Either your program needs some tweaking,or,data entry needs to do a better job.IDK for sure,but,I think it would be a safe bet to say that the JY 8:1 CR 500+ HP 454 you claim to have had dynoed & goes 8 seconds in your Chevelle is really exists on your computer since several ppl requested dyno sheets,time slips,etc,but,got nuthin except an attitude from you.If I had built that motor,i'd have proof posted everywhere.I apologize in advance if you prove me wrong.
Peanut Port 454 build bobbypantera Engine 71 10-04-2013 06:38 PM
454 peanut port timing hotrodcommuter Engine 11 11-01-2011 02:41 PM
Can peanut port heads make power up to 5500rpm? turchiac Engine 4 11-11-2010 08:47 AM
Peanut Port 489? airboat Engine 4 10-31-2009 09:01 PM
Will an oval port intake work with round ( peanut ) port heads? quintorca Engine 6 02-14-2008 11:43 AM
