How Do I Get 500hp - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-10-2010, 07:39 AM
Before making that decision, consider what vehicle this is going in (I don't see that mentioned anywhere in these posts).
180 would likely RPM limit you but provide great torque and clearly great HP: 450HP!!
195 would have a better chance of winding all the way upstairs to make that 500HP Naturally Aspirated. You'll need a different cam, titanium retainers, stiffer springs, super good lifters, sacrifice low end grunt.
Unless this is a really light car, or strip set-up; I would think you'd be happier with the 180.
This is my opinion, I'm not telling you what to do, and you shouldn't make your decision based off of what I'm telling you.
Put up some more info about the intended car, and intended use, and you might receive more answers. Goodluck
  #17 (permalink)
Old 06-10-2010, 08:00 AM
OLNOLAN's Avatar
The 500/500
Hey Novacrazy, I kept thinking about this recipe when I saw your thread. I finally got around to finding it. Good food for thought. olnolan
http://www.hotrod.com/techarticles/e...ine/index.html
  #18 (permalink)
Old 06-10-2010, 08:23 AM
1970 Nova. Th400, Dana 60 4.11 Gears Street/strip
  #19 (permalink)
Old 06-10-2010, 04:45 PM
ericnova72's Avatar
More for Less Racer
With those facts and your last few posts, I say 195's, no way will the 180's make you happy if you are thinking of any strip action at all.
  #20 (permalink)
Old 06-10-2010, 06:15 PM
Even If I Limit My Rpm To 6500
  #21 (permalink)
Old 06-10-2010, 06:27 PM
Any Cam Suggestions. Hydr. Roller. I Already Have A 3000 Stall Converter.
  #22 (permalink)
Old 06-11-2010, 10:30 AM
my87Z's Avatar
Veteran/Firefighter-EMT-I CRT
for the converter you have and with you wanting to stay below 6500rpm i think this cam would suit you well.
http://www.summitracing.com/parts/HRS-110265/
i still think that a solid roller might fit a little better but this cam has some pretty nice specs and should put you shifting at about 6300-6400rpm. and your stall is 3000 rpm which is 600 rpm above the begining of the cams operating range which is perfect. with this cam i would certainly go with the AFR 195's and nothing less, i think this cam with those heads and about 10.5ish:1 compression that you should be close to your hp goal, my personal estimate would be about 475hp, (as long as those AFR's can flow about 265-270cfm @ .550"ish lift, and i'm talking real world not advertised numbers)
personally i wouldn't go with a larger cam than this unless i was going to use a solid roller cam, but that is just my opinion
  #23 (permalink)
Old 06-14-2010, 11:05 AM
How Much Rpm Can My Scat Cast Crank Handle
  #24 (permalink)
Old 06-15-2010, 11:44 AM
my87Z's Avatar
a cast steel SCAT crank can easily handle 6500rpm, maybe even some 7000rpm but not for extended periods of time like in circle track
  #25 (permalink)
Old 06-15-2010, 01:43 PM
ericnova72's Avatar
More for Less Racer
Myself and others have had no problems with 3.48" and 3.75" Scat cast steel cranks run to 8000 rpm in street/strip engines, the 3.48" stroke engine has seen 8400 repeatedly for a few summers with no problem. Cars have been in the 10's 1/4 mile and hit with 200hp nitrous regularly too, no problems with the cranks.
Using light pistons/rods makes a big difference.
I wouldn't try 7500 rpm constant with these cranks in a circle track car unless you want to take the chance, I have no experience with roundy motors.
  #26 (permalink)
Old 06-15-2010, 06:55 PM
Any Sbc 357 Combo's Suggestions. Street Strip. 3000 Stall Conv.
  #27 (permalink)
Old 06-15-2010, 07:01 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Sorry novacrazy2007 i just can't resist i have been holding back
Put a Hemi in it. Just kidding sorry if i offened you in any way, Sometimes i just can't help myself.
Cole
  #28 (permalink)
Old 06-16-2010, 06:54 PM
do you have a hemi in your camaro? not offended at all.
500hp chevy 350 run with 98-gas from my setup? Berres Engine 9 07-27-2009 07:22 AM
streetable 500hp 327? rlackey Engine 31 03-02-2009 09:02 PM
Patriot Performance 500hp 383ci skibum845 Engine 1 02-11-2009 10:05 PM
Building a BB Chevy. I want 500HP tommytempest Engine 39 03-06-2007 06:48 PM
400 - 500hp from a 1971 351c. mike Clothier Engine 2 09-03-2003 06:29 AM
