how do i get mounted? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2003, 03:58 PM
Post how do i get mounted?
i have a 76 camar, 3 bolt clmasheel style motor mounts, both sides need replaced and i was wonder, how exacly do ya get to the nuts inside the subframe that hold them in, from what i can gather it looks like i have to lower or remove the lower control arm and go at it this way, it it going to be that simple just to drop em down, or am i going to need a spring compressor ect to do this job?
any advice would be helpful at this point
thx camaro76
Old 02-14-2003, 04:25 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
I don't know if this will help you, but I have touched a welding rod to the nut (lower than needed amperage to weld) so that the rod sticks to the bolt. After I had this nice little "handle", I snaked the nuts into position. You can then bend the rod to a position that matches the angle you need. After you have the bolt started, just use an impact gun to tighten the bolt (holding the nut from spinning is usually not needed with an impact). After you have the bolt tight, just twist the rod and it will break loose from the nut (if it hasn't already twisted off from using the impact).
Old 02-14-2003, 05:16 PM
Post
thats a realy cool idea, that would have been helpful back in shop class, im in my driveway now and don't have any operating air tools, i got the tool, just my home compressor is to weak to power them
Old 02-14-2003, 06:12 PM
drgnwgn289's Avatar
Post
Damn, I saw your topic "how do I get mounted" and i was gonna give you some very different advice...
Old 02-14-2003, 06:16 PM
dinger's Avatar
Post
dam, drgn, you too? brilliant minds thinking alike again..lol. maybe it was just tooo easy. Dan
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 02-14-2003, 06:52 PM
Post
hehehe, glad you guys likes how i make topics, i try and be creative with them to draw atention, seems to work most the time, but i still need to know if i must remove the lower conrol arm, and what would be the best way to do that
Old 02-15-2003, 06:45 AM
Post
bump
