how do i get my 1937 oldsmobile low?
hey i just got a 1937 olds humpback and wanna get it sitting as close to the ground as possible... i want to keep mostly standard suspension with drum brakes. i have been looking everywhere for dropped uprights or spindles but havent had any luck with it..
so if anyone knows about how to get a set or has a set or even any other method apart from chopping springs . it would be greatly appreciated. thanks
If the lower control arms are stamped steel as opposed to a cast or forged unit, they likely can be stepped to gain you typically a 2-3" drop on the front end. That along with a minor shortening of the springs should get you the front end height you are looking for with the stock front suspension.
For the rear, de-arch the springs, move the forward spring hanger on the frame up, or alter the rear shackles, or a combination of all the above to get it low. If you need more details, let me know. A photo showing the front upper and lower control arms could be helpful. Andy |
lowering
Fatman has frame stubs to fit it with a Mustang two front end, or you could
subframe it. The non chevy gm frame/suspension from that era does not lend itself to easy modifications. I think fatman made dropped spindles for these at one time- you might check with them for that. Good luck with your project. Jim |
the control arms are cast. i can get a bit out of the tyres and the springs but id like to get that extra 2-3 inches out of it.. yea ill try to get some photos through .... that is once i work out how to use the computer
. yea the back will be easy enough with de arched springs the chassis rails will get in the way with much more and i dont really want to cut it up. yea ok ill get on to fat man.. thanks.
| vaccum too low?? 357 with comp 280H cam | 357 Cutlass | Engine | 19 | 06-29-2008 10:26 AM |
| How low is too low? | Ripped | Suspension - Brakes - Steering | 8 | 06-28-2008 11:52 AM |
| 700r4 won't stay in manual selected low | lldsad@centurytel.ne | Transmission - Rearend | 4 | 06-12-2007 06:42 PM |
| increasing low end torque | fast68 | Engine | 3 | 07-31-2006 04:27 PM |
| Misfire at low RPM | 65Stanger | Engine | 9 | 07-29-2006 02:08 PM |
