I have a 1981 Camaro. It had a 267 in it, and I swapped it for a 350. The car came factory with cc, and I believe the speedo cable goes from tranny to cc unit, then up to the speedometer. Can I run it from the tranny to the speedo unit like a normal vehicle and then remove the cc unit? Thanks for the help, Bill
If you don't want the crise remove it it run a longer cable. You might need to change the drive ratio for the speedo in the trans to get an exact speed, but any competent tranny shop can do this.
Just find a Camaro the same body style as your that does not have cruise and get the speedometer cable out of it. Grease it up real good......it is 20 years old...amd install it in your car.
The speedometer will be correct IF it was correct before. Cruise has NOTHING to do with the the speedometer gears in the transmission
check with your local chevy dealer by one piece cable (delete the fact it had cruise) when you order the cable, after all its a camaro good parts to sell for gm.
[ April 13, 2003: Message edited by: airworld2 ]</p>
Your local auto parts store should have the cable you need on the shelf. Check the dealer for prices just for fun. Some things can be bought cheaper at the dealer, believe it or not!
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
