Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How the $%$%#$ do I get this tilt column apart......
Old 01-21-2004, 10:37 PM
fire power's Avatar
fire power fire power is offline
I took a look at your photo and can not identfy for sure but you said it was a tilt, so the next step is to pull the piviot pins out and the two parts will seperate.
I went back and looked at the photo again ,,,,Its been a while but I did some of that type in the past the sheet metal cover slides down and then you can pull those piviot pins , cant remember what holds the sheet metal piece from sliding but its gotta be there good luck Ill check back
