How Do I Hide Master Cylinder? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2006, 01:31 PM
I have a 56 chevy sedan with body drop that will have 4 wheel disc brakes. I have a 96 trans am master cylinder with the power booster. I can't fit that power booster under the car when hiding this master cylinder. This is the cylinder I would like to use considering it's proportioning valve is set up for 4 wheel disc brakes already. Is this a problem ditching the booster? Will I see a big difference in braking when loosing the booster? All help is much appreciated.
Old 02-07-2006, 01:38 PM
TechnTool's Avatar
OldSchool MotorHead
That depends on how the pedal is connected to the master cyl. The booster makes a huge difference when the pedal pushes directly into the master cyl, but if you have a lever type linkage that multiplies the pedal effoert, then you may be able to get away with ditching the booster. Personally, I would use the booster.
Old 02-07-2006, 02:27 PM
ckucia's Avatar
I don't know enough about this to know how difficult it would be, but you could possibly modify a Hydroboost booster.
This was on some of the 70's/80's FS Cadillacs and is on many GM trucks. Uses pressure from the PS pump as a brake booster rather than vacuum. Takes up a lot less space.
Old 02-07-2006, 03:32 PM
48ChryslerRodder's Avatar
Stuck in the past.
I've seen ads in Streetrodder that advertise an offset master cylinder/booster setup. When there is no room on the firewall in the engine compartment it allows to be mounted under the dash. You could try an under the floor setup but I think you would have more headaches that way.
Old 02-08-2006, 08:04 AM
To minimize the look of the booster and M/C, you could paint them the same color as the firewall so they blend in and not "pop" out when you lift the hood. Just a thought
barry
Old 02-08-2006, 05:19 PM
if you go to a 6 to 1 or 7 to 1 pedal ratio...it should work fine.
39 Deluxe master cylinder adapter? MM in NM Suspension - Brakes - Steering 4 09-30-2005 03:42 PM
4 wheel disc master cylinder qckshftn56 Suspension - Brakes - Steering 2 05-23-2004 10:30 PM
Confusing master cylinder ports... Externet Suspension - Brakes - Steering 2 12-08-2003 08:18 PM
Help with continuing master cylinder problem chris57 Suspension - Brakes - Steering 3 09-30-2003 02:35 PM
Help! Going Nuts! Mysterious Master Cylinder delstretcho Suspension - Brakes - Steering 6 03-11-2003 05:54 AM
