How do I identify a 318, 340, 360 Mopar?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2006, 05:28 PM
I found a modified and chromed '79 360 for sale for $200.00, how do I tell if it's a 360 and not a 318? The guy guarantees that it runs good. I'm a Chevy guy so I'm not real familiar with Mopar. Is the 360 a good dependable motor? How much H.P. does a 360 have? Did they have any known problems with bearings and stuff? Is a '79 360 just as good as the older ones?
Old 04-19-2006, 05:51 PM
Wiki Edits: 49
Look on the front of the block just below the driver's side head. There should be a stamped number there which will include the displacement.
Old 04-19-2006, 06:04 PM
Is there a casting id web site I can use like Mortec has for Chevy's
Old 04-19-2006, 06:26 PM
73oldsman's Avatar
http://www.yearone.com/updatedsingle...gineinfo1.html This may help some, I hope.
Old 04-19-2006, 08:15 PM
Wiki Edits: 49
Yep...... Small Block Mopar Block Casting Numbers
340 mopar motor questions tlopushansky Engine 4 02-09-2009 02:54 PM
Mopar 360 Motor Question........ STATUTORY GRAPE Engine 2 04-14-2006 09:10 PM
318 build up(or 360) JeepStang94 Engine 5 02-11-2005 04:37 PM
Swapping 273(or 318) to a 340/360 in Mopar A-body Gilligan Engine 7 09-18-2004 09:42 AM
oil pan for 318 mopar oldnable Engine 1 08-22-2002 01:52 AM
