how do I make my tbi fuel pressure regulator adjustable 2.8L GM - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2006, 03:41 PM
hELLO I have a 2.8L s-10 and are hunting for ways to make the pressure regulator in the throttle body adjustable.......I know I have seen posts somewhere but cant locate them.......anyone know how or have done this modification ?..........I need to do this because I put the 4.3L throttle body on it.........along with other mods.
Old 04-05-2006, 04:30 PM
The pics are missing but maybe you can figure it out from the text
http://s-series.org/Sections-article22-p1.html
You can also use any of the ones designed for other GM TBI car/trucks. They often won't list the S10 application but all of the TBI throttle bodies are based on the same housing.
http://www.jetchip.com/products.asp?...el=10000#10000
fuel pressure TIM LIMES Engine 8 05-02-2009 01:59 PM
1:1 Boost referenced fuel pressure regulator means?? 84Z Engine 1 11-09-2004 11:54 PM
fuel pressure accessory CORNFUSION!!! killerformula Engine 10 07-06-2004 08:02 PM
Fuel Pressure DoubleVision Engine 18 05-31-2003 05:49 AM
350 GM Goodwrench Caprice engine in 3rd Gen TBI F-Body? wrmason3 Engine 2 09-14-2002 07:01 PM
