how do I measure wheelbase ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2005, 02:21 PM
How is the correct way to measure the wheelbase? I would think that you would measure from the center of the front wheel to the center of the back wheel. I want to make sure I'm doing this correctly, thinking about putting a ford ranger long bed frame under my 51 F1. If I'm measuring correctly there is only a .1 of an inch difference according to a web site I found the Ranger's dimensions. Also is there any other points that I need to mearsure that might give me problems. Thanks for your help.
Old 05-20-2005, 02:25 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Yep, that's how you do it. Just make sure the front wheels are pointing straight ahead. Great to hear of someone swapping a frame from something other than an S10. I asked the question, "why not a Ranger in stead of an S10", in a thread just last month.
Old 05-20-2005, 03:17 PM
broncoII88's Avatar
Do the right thing...
Yeah I remember that thread. By the way Willy's, you never voted for my best car poll. I had the choice of gasser in it just for you!
Old 05-20-2005, 04:18 PM
Wiki Edits: 21
Oops! Sorry, I didn't read carefully enough. I thought you just addressed ricers, mini trucks and such. I'll be sure to chalk one up for the good guys!
Update, 3 minutes later; I just went to your thread and didn't see gasser as a choice. Cruiser is as close as you get, which is close but no cigar.
Old 05-20-2005, 04:31 PM
Nightfire's Avatar
Young & Idealistic
Last journal entry: 1950 Fargo - losing hope
Wiki Edits: 4
You looked in the "best look at me" car, Bronco posted another one a week earlier about "different cars for different people"
Mike
Old 05-20-2005, 04:42 PM
Wiki Edits: 21
OK, I found that thread. I had voted, just didn't comment. Don't spend that much time in the lounge so a lot of that kind os thread gets by me.
Old 05-20-2005, 05:52 PM
broncoII88's Avatar
Sorry dude, but thanks for voting!
Old 05-25-2005, 03:30 PM
Tazz
If the front and rear rim's are the same size...
looking at the wheel...go to the 9o'clock position to the 9o'clock position from one wheel to the other,front to back. That will give you center to center overall measurement.
Tazz
Rat Rods Rule!
Old 05-25-2005, 03:40 PM
Wiki Edits: 21
Tazz
Rat Rods Rule!
Be careful; that will only work if the tires are exactly the same diameter. Can't do that for Big-'N-Littles.
How to measure toe-in for 1932 hot rod Limey Simon Suspension - Brakes - Steering 8 03-14-2005 06:36 PM
Wheelbase data deleteall Suspension - Brakes - Steering 1 04-25-2004 05:22 AM
A/C Fittings How to measure? 76chevyc10 General Rodding Tech 2 04-24-2004 09:04 AM
How to measure orffice on spray gun? unioncreek Body - Exterior 1 02-02-2004 03:14 PM
'83 cutlass wheelbase dharroald Hotrodders' Lounge 2 02-21-2002 04:01 PM
