How do I paint here? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2011, 04:14 AM
The door jambs have those stickers. I have been told to just tape over them. But how clean an edge will I get if I just tape over them?
Is there another way?
Old 04-09-2011, 05:16 AM
poncho62's Avatar
Wiki Edits: 5
Get new stickers, but that can be a hassle with serial number ones and such.....Maybe the pros here have an idea, Must be a common problem with these guys
Old 04-09-2011, 12:37 PM
TucsonJay's Avatar
Put your masking on as accurately good as you can, to avoid covering any of the jam. Trim off any overhanging tape with a #11 xacto blade. Should be fine.
Old 04-09-2011, 02:52 PM
Righto. I guess 3M has the best tapes then?
Old 04-09-2011, 08:01 PM
Nastynotch347's Avatar
I've had good luck with the green 3m and not applying lighter coats to keep the edge down.
Dupli Color Paint Shop auto paint Lacquer ChevyTruckGuy Body - Exterior 231 04-18-2015 09:56 PM
Engine paint, high temp paint, Powerder coating??? zbhover Body - Exterior 18 06-01-2011 07:16 PM
What type of paint sticks to sanded, pre-existing paint? Rockworthy Body - Exterior 19 01-25-2011 10:41 PM
prepping my car now for paint. questions on how far to sand existing paint ((sr)) kelly Body - Exterior 3 07-15-2009 11:49 AM
base/clear paint for underside of vehicle or other paint? hrc200x Body - Exterior 5 06-27-2007 09:55 AM
