How Do I Phase My U-joints Again? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2008, 11:14 AM
Just tried searching, and did not come up with much.
Which way do I phase the u-joints on the steering shafts again? I have two
Thanks
Mark
Old 02-23-2008, 11:34 AM
Irelands child's Avatar
http://www.clubfte.com/users/jniolon...nephasing.html
Irelands child
Old 02-23-2008, 12:02 PM
AntnyL's Avatar
Thanks
Mark
The U-shaded ends need to be parallel with each other.
Old 02-23-2008, 12:06 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi Mark,
The yokes need to be in the same position on each end of the shaft. I don't knowhow to put an illustration up.
Good luck,
Rich
Old 02-23-2008, 12:41 PM
look at a driveshaft, do your steeringshaft the same way...enough said...
Old 02-23-2008, 02:49 PM
Got it,
Thanks
I couldn't check the driveshaft, no driveshaft in the car yet, and nothing else I have has a driveshaft, not even my car that was in Hot Rod last month.
Mark
vortec vs phase 2 heads 71vegagt Engine 3 01-29-2006 06:12 AM
Ball Joints....not a hot rod but.... screamin340 Suspension - Brakes - Steering 7 08-05-2005 04:51 PM
how do I remove universal joints Neophyte Transmission - Rearend 11 02-05-2005 12:36 PM
Front end U joints Trav Transmission - Rearend 2 10-06-2003 07:52 PM
Ball Joints Question!!! bg Suspension - Brakes - Steering 2 03-31-2003 07:26 PM
