Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How do I prevent dry spray and orange peel?
Old 05-08-2012, 05:16 PM
rusthater89's Avatar
rusthater89 rusthater89 is offline
Yes, it isn't wet enough. The problem, the balance you need to keep to spray it wet enough on something like that without spraying it too wet and getting runs. Overlap is the hardest part. You are spraying all kids of angles and hitting the same spots sometimes over and over, at that point it can get too much applied and run. It is a fine balance to spray something like that all over without doing this.
Right, Basically I have to maintain good overlap without spraying too much on one spot. So basically when I spray my other inner fender I will try to focus more on overlap to minimize dry spray.
