How do I prevent dry spray and orange peel? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-12-2012, 09:20 AM
rusthater89's Avatar
Originally Posted by Handfull54
Just remember that if you are painting in your garage to beware of your hot water heater if its in there. As a retired Fire captain I have seen people blown own to the street when those fumes reach their ignition point. Also be sure you have a big enough air compressor. I bought 2 little ones and my paint would be dry in some spots and Ok in others. If your compressor is running all the time it's not keeping up. I bought a 80 gallon 7 hp compressor nd all the problems went away. Just my experience.
I do my primer in my driveway. I will do the final paint in my garage with the floors hosed down, since I'll have more room in my small cramped garage with my car back together. This car is not a restoration, more of a hot rod so I am not concerned with getting paint on every nook and cranny. My compressor keeps up fine, in fact barely turns on when I spray. Thanks for your concern though, that is pretty dumb though to paint near a flame.
  #17 (permalink)
Old 05-12-2012, 09:26 AM
Just curious, I have limited space and only one work stand so when primed parts flash I try to carefully move them to a spot to dry while I prep the next piece. The primed parts are still soft and despite tryna be careful sometimes I end up nicking it and a small spot gets exposed. Do you guys just touch up with some rattle can primer or do you guys try to mix up some more epoxy for the small touch up?
I always get orange peel! I hate orange peel! shad9876 Body - Exterior 15 10-14-2008 08:45 AM
Urethane peel or just good ole orange peel? BIGSKY Body - Exterior 18 01-24-2007 02:01 PM
orange peel Rustyoldtruck Body - Exterior 8 07-15-2005 08:24 PM
Spray Gun Tip Size to prevent orange peel Gro Harlem Body - Exterior 5 03-14-2005 02:57 PM
orange peel CARGUY Body - Exterior 7 07-23-2002 05:04 PM
