how do I prime a oil pump in a big block chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2011, 03:58 PM
Checking to see how I prime a oil pump in a newly built big block chevy
Old 07-01-2011, 04:05 PM
These SummitŪ oil pump primers make it easy to get oil to the top of your engine. They are designed to fit in your distributor hole and require no modifications to use. The Chevy primers feature a billet aluminum adjustable collar and black oxide coated steel shaft, while the Ford primers use a standard steel shaft with no collar.
http://www.summitracing.com/parts/SUM-901010/http://www.summitracing.com/parts/SUM-901010/
Big block pil pump on small block Chevy dallam11 Engine 22 03-24-2012 07:36 PM
prime an oil pump on big block chevy Chucky5150 Engine 17 06-06-2010 11:37 AM
cant prime oil pump in bbc HEGLER Engine 15 04-08-2008 05:24 PM
How to prime an oil pump/system? Steve-0321 Engine 3 09-22-2004 08:48 AM
