How do I protect my outdoor project? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2005, 10:59 AM
Dejavu's Avatar
Not so New Member
Last journal entry: Trying to make a custom valance
This has probably been discussed before but I'm not sure how to search the topic. I'm forced to work outside and have gotten to the point of welding patches and replacing sheet metal. Can you recommend something that will protect my work until I'm ready to get into real paint prep. I'm currently doing the engine bay (motor has been pulled) and shock towers and my long term plan is to detail them for a better than stock look. Any help would be greatly appreciated!
Thanks,
Fred
Old 07-18-2005, 11:16 AM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Check this out.Garage
They have them at the store on sale for like $150
Old 07-18-2005, 11:23 AM
Dejavu's Avatar
Not so New Member
Thanks, BEE4ME, my mistake my question wasn't clear enough, I'm actually looking for the best primer/coating to use as I finish each section of work.
Thanks again,
Fred
Old 07-18-2005, 08:25 PM
Bee4Me's Avatar
That would be epoxy.
Old 07-18-2005, 08:55 PM
What u want to use is a self-etching primer. This will seal your bare metal from the elements. It is transparent with a tint to it, and all it takes is a thin layer. I work in a street rod shop and with the humidity in texas, i have to spray self-etch on all my bare metal before i leave for the night, b/c ill come back in the morning with surface rust already formed.
Old 07-19-2005, 04:53 AM
302 Z28's Avatar
Read the spec sheet on any self etching primer you use, it may or may not be waterproof. The only sure way to protect bare metal is to clean it very good then use a quality 2 part epoxy on it. Southern Polyurethane has one of the best I have ever used.
Vince
Old 07-19-2005, 05:28 AM
Dejavu's Avatar
Not so New Member
Thanks for your responses , with 100% humidity the last few days I had light rust overnight .
Fred
Welding frame, how to protect computer? 76chevyc10 Electrical 4 07-06-2004 12:51 PM
Protect your uphostery with slip covers cboy Interior 3 03-04-2004 07:46 PM
How to Protect from Rust Until I Paint horvath Body - Exterior 16 08-22-2003 10:27 AM
