ok, its a bit more complicated than you think, that switch that your showing is a PRNDL switch (range sensor), which is not needed on the 94 as you have shown.
now this doesnt mean just yet that your cant run the 95, but your going to have to pull the pan on BOTH trannys and match up the electronics. while im pretty sure the 95 is a PWM unit, im not sure the 94 is. this is listed from the parts book from transtar: 425D Solenoid, TCC & Wire Harness (Non PWM TCC & PWM 3-2) 6 Solenoid..................... 1 93-95 74425N 5D-173 425D Solenoid, TCC & Wire Harness (Blue Connector) (PWM TCC & 3-2)........................... 1 94-96 74425Q 5D-173A it shows the possibility from what i see on these parts, but without matching things up inside, your going to have problems. if by chance they both have the same electronics in the same places, then id say all you should have to do is change the manual arm shaft that goes through the case, along with the manual arm, and you wont have to buy any shifter/cable setups. just install. i recommend pulling the pan on both trans, and take pics of each, with the filter removed, so we can see if theyre any different, then i can give you a more definite answer. if by chance crosley chimes in, he will know right then because he knows them better than i do on the changes through the years. |
nine4gmc;
you are working on a 4L60E trans. Lock up kit is not even in the discussion for these transmissions. And, the 1995 unit and 1994 unit are not identical on internal operations for converter clutch control You need to drop the pans, swap out the shift shaft linkage arms. The 1995 trans with the MLPS on it has a longer arm sticking out from the trans. The 1995 trans has a PWM lock up system for the converter clutch. That will need addressed to replace the 1994 trans in the 1994 vehicle
At the Bonneville Salt Flats, first gear is known as 130 mph. |
ok after I swap shifter arms inside the trans, that will take care of it physically not fitting then what could i do about the pwm clutch?
i have the complete engine harness and computer from the 95, along with the trans but the 94 truck is tbi and running on its own ecm and though the harness has the same engine connections as the newer one, it has fusible links instead of an actual fuse/relay block like on the 95. i started hacking into it tracing the plugs on the side of the trans until earlier when i saw tnsmith10 said that was only the sift indicator plugs. would it be hard to piggy back the 95 ecm to run the trans. sorry im such a noob, i am an upholsterer by trade but have done home/auto sound/security for years, custom air/hydraulic suspension as well, just never been inside an overdrive automatic trans other than to change the filter. worste case, i guess i could do the shift arm swap then change the trucks complete dash, dash harness, engine harness and ecm over to 95. |
i figure you will end up with a cluster mess and the vehicle will never operate again by attempting to change all the dash electricals.
the 1994 ECM will operate the 1995 trans fine. You need to alter a few items inside the trans or rebuild the 1994 trans and save the work and possible grief
| 1995 Lincoln Town Car, gas smell inside vehicle problem | ret_marine2003 | Hotrodding Basics | 1 | 06-20-2010 11:30 AM |
| 1995 4L60e without reverse | crazy1 | Transmission - Rearend | 3 | 02-17-2010 05:23 AM |
| 1994 4L60E Problem | Redneck8686 | Transmission - Rearend | 8 | 07-24-2009 05:21 AM |
| 4l60e 1994 Gmc 1500 | AMp.Wolf | Transmission - Rearend | 19 | 04-25-2009 03:24 AM |
| 4l60, Or 4l60e 1994 Gmc 4wd | buddy powell | Transmission - Rearend | 4 | 10-14-2004 06:16 AM |
