How do I put on a starter brace on a 350 sbc? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2009, 06:01 PM
Hello guys I have been reading about how your supposed to use a starter brace on 350 small block chevy. I currently have two trucks with 350's in them and neither one has a starter brace on them. The 86 s10 I have has a gear drive starter on it and my dad said I don't need one since it does not pull as hard as a torque drive starter. My other 96 s10 has a plain old torque starter and I don't want to risk damaging my new 350 to put in it this weekend. I will eventually get a gear drive for it when funds permit but for the time being I will use whats on it. But the question I have looking at a picture of one on summit's website I can't tell how it goes on. Any help or photos would be nice. Thanks for help guys.
Eric
Old 05-18-2009, 06:28 PM
poncho62's Avatar
Wiki Edits: 5
If you are talking about a stock starter, the brace goes from one of the long bolts that holds the starter motor onto the housing to a boss on the side of the engine block under the head, just behind the motor mount. Look at the bottom of this diagram.
Old 05-18-2009, 06:29 PM
Starter Brace
The rear of the starter has one bolt that is longer than the others. One end if the brace attaches to this bolt. The other end of the brace bolts to the engine block via a threaded hole in the block located just below the block/head joint.
Old 05-18-2009, 06:36 PM
Hey cool thanks guys will these braces work on aftermarket mini starters as well? Thanks again
Eric
Old 05-18-2009, 06:44 PM
poncho62's Avatar
Wiki Edits: 5
Not sure....it would likely have to be longer....ask where you get the mini starter
Old 05-19-2009, 07:58 AM
*** Please post solutions ***
Has anyone made homemade brackets... if so please post a pic of what you did... I would like to do this.
SBC Starter Bolt Pattern, Patterns? 63ChevyII Engine 13 09-21-2012 08:43 PM
400sbc to 350 sbc 77k20 Engine 2 04-20-2009 10:23 AM
350 Chevy starter pinion to flywheel clearance Bonehead4x4 Electrical 8 03-28-2009 03:49 PM
cHEV 4.3L Bore size..compare to SBC 350 (both stock) boneyard Buick Engine 5 09-25-2006 07:29 PM
350 starter won't line up right-? 31 Ford A Engine 21 08-26-2006 07:51 PM
