How do I quickly prep my garage for painting my car inside it?
I'm going to paint my car for the first time. My garage is the only place I can think of that won't be windy or too cold. Where do I get a bunch of "garage masking supplies"? I don't even know what to ask for. Is it expensive? I don't want the paint that's in the air to get all over everything else in the whole stupid garage.
You can build a plastic sheet booth using common sense and materials you can get pretty much anywhere. For mine I covered the roof joist since I had insulation up there and secured the plastic by stapling through small pieces of cardboard so the staples wouldn't pull through. Duct tape will seal up the seams. The real challenge is finding a good way to secure the plastic to the floor. Duct tape usually won't do it because of dust on the floors, no matter how much you clean. They'll need to be weighted down along their length.
Buy a couple of box fans to blow out the door. Seal the entire door with plastic and cut holes and seal the fans with duct tape. On the opposite end mount a couple of central heat filters the same way. 3 box fans on high and three or more filters would be better. You'll need to generate a lot of air flow to move the considerable fog out of the work environment. Tips learned from experience: You need a LOT of lights. Several multi-tube florescent fixtures at a minimum. Once you start spraying the fog will make seeing well difficult, and the better you see the better your work will be. Also the walls of a temporary plastic booth like this will bow inward when set up this way(with the fan blowing out, making a vacuum) so make sure you have lots of extra room when you build the booth size. You can set it up where you put a filter on the fan and blow into the booth so it has positive pressure. This reduces the chance that dust is pulled into the booth by the vacuum. But I have always used the fan blowing out because it's been more important for me to get all the fumes out of the entire garage. I've had good results using temp booths. Also remember that most trash found in paint is from the vehicle itself, so clean and blow off with compressed air as much as possible before you start shooting color. This is one reason a lot of guys like to epoxy and shoot color all through the interior. Just to lock down sources of dust that might get airborne when hit with the blast from the gun. Good luck. Bruce Last edited by TNshadetree; 01-19-2011 at 08:04 AM. |
This is how I did mine. It has a 900cfm variable speed fan set at about 75% of rated output in a window and a set of furnace filters to clean the inlet air. The ceiling and garage door were also covered while painting. The results was a 99% free of crud paint job, and probably as dirt free as many body shops.
![]() Dave W |
Slightly different from those above...I used inexpensive plastic tarps from Fleet Farm. They are heavier weight than visqueen and don't tend to get sucked inward or move outward with the air pressure from the fans and the gun. They also come with grommets so they can be easily hung from the ceiling on hooks which can be left in place for the next time you need to have a paint booth. I also find that they do not require being weighted around the bottom edge. Note also in the picture the Jet air cleaner hanging from the ceiling. In addition to my intake and exhaust fans (I use box fans), I run the Jet on high to help filter the air during the shoot.
In this second shot you can see my "mixing table" in the background as well as a sheet metal box on the table which is for testing the gun pattern and making final adjustments to the paint flow before actually shooting the car. Also note the blue tarp taped to the floor which was an extra precaution because the car body was so close to the floor I didn't want to have any dirt from down in the surface of the cement blowing up into the paint. In addition, I opt to spray the floor down with a little water mist before shooting each coat. I use a small garden type insecticide sprayer to lay down the water. (Note: there are many who argue against using this technique, so keep that in mind.) Final note regarding "stupid things we all have done". Don't EVER throw open your overheard garage door immediately after shooting. Let the paint dry first. Many a guy has opened the door only to have a cloud of dust and debris fall from the rails down onto a pristine paint job.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod. |
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
But --- whatever works for you to keep the dust off of the surface is the best way, regardless of how you choose to do build your "booth". Dave W |
i got a new furnace this year and saved the big squirrel cage fan from it for this purpose.
but now that i'm thinking about it, is this going to be too much exhaust fan? will it be windy in there, or does the fact that you've built a room with only the furnace filters for intake, keep it from getting to much airflow? the reason i ask is because i use a similar furnace/fan screwed into the rafters for heat in the garage and when it is on it gets down right windy under it. |
My garage was too small and crowded to paint in it. We built a outdoor booth in the backyard. Might be an option if you have the space. Ended up selling the canopy for what I paid for it. Worked really well and had no trash in paint.
Pictures and write up here if you are interested: http://chris66dad.tripod.com/id24.html |
Dave W |
I just wanted to point out my biggest mistake when I first started. After a few tries, and lots of dust I realized the debris was coming from my hair. Like most people I thought a fancy paint coverall was to protect the user, not the other way around. Now with the coveralls I spend half as much time trying to get the room dust free, and concentrate as much on the vehicle, and myself being dust free. I even shower, and put on clean lint free clothing under the coveralls before painting now. You may notice that when you bend over in coveralls a whoosh of pressure will billow out of your hood, thats not good so keep clean even underneath.
Be careful with hanging plastic on the ceiling. Overspray and dust will stick to it and if slightly disturbed it WILL fall onto your project. I know from personal experience. Here are a few pics from my garage. I have a 24" fan built into the back wall. I typically clean the garage the day before and do my masking, then the next day, lighty blow the car off and tack and shoot. I still get dust, but it sand out. I'm always looking for tips on garage set-ups!
I typically remove any large items and then hang plastic around the compressor to stop any dust from flying off of it. ![]() ![]() My fan. I built a box to hold filters infront of it. I have fresh air that enters from the other side. Although the fan can pull more air the can be supplied. I may install a window on the front of my garage come spring that I can slide a filter in. So I'm not sucking air through EVERY single crack in the garage and pullling dust. ![]() 13 hours later, lol
OMG what a hassle all this is!!!
The whole reason I want to paint my car at home is because I don't have a lot of time and money to spend on it!!! It looks like there is easily as much work just prepping the garage to spray than the actual paint job on the car! I had no idea this was all so involved. What about this: are there paint booths that I can just use once to spray my car in, so that I don't have to make one at home from scratch? I live in a medium sized town and don't have the room outside my house to spray a lot without it possibly blowing over to the neighbor's cars/house.
| Recent Garage - Tools posts with photos |
| painting inside the cab | daveid | Body - Exterior | 12 | 12-13-2010 09:28 AM |
| Tyvec inside garage | snorulz | Garage - Tools | 22 | 11-11-2010 08:32 PM |
| Painting inside garage on wet and rainy day | cyberdork | Body - Exterior | 44 | 04-29-2010 01:28 AM |
| Prep for Painting | streetrodderdoug | Body - Exterior | 4 | 05-11-2006 11:35 PM |
| Painting inside of Garage | Nightfire | Garage - Tools | 10 | 06-30-2005 07:33 PM |
